Digital For Mississippi
MississippiPI
All over the Great State of Mississippi
I am looking for a scanner that will be able to pick up the Hinds County (MS) Sheriff's Dept here in Mississippi. I understand that Ridgland and Madison are also on this system. I am so confused as to what type of scanner will work--any suggestions is appreciated.
Thanks and be safe
n2mdk
Ames, IA
This really should be in the General Scanning Forum, since reading the info in the database says they want to add 700MHz systems to it you will need either the Uniden BCD996T or BCD396T or the GRE PSR 500 or PSR-600, right now the GRE's seem to be top dog.
