Digital Radio by Motorola
daniboy
Hello
Any one knows some digital radios from Motorola.
I Have a question, how can we see the GPS data sent by the radio?
I hope someone can help me...I'm new on this area.
thanks anyway
best regards
Daniboy
N
N_Jay
Guest
Hello
thanks anyway
best regards
Daniboy
What digital radios?
What GPS data?
daniboy
so the equipment is a Motorola DP3601, and has a built GPS inside....I need to know the format of GPS Data ssent by the equipment
Best regards
daniboy
N
N_Jay
Guest
Best regards
daniboy
That is MOTOTRBO.
You will need to either buy a radio and play, or talk to Motorola to see what they have in the way of an SDK and support for third party development.
Are you trying to get the GPS off the air, or out of the base end radio?
daniboy
Yes is a MOTOTRBO.
I have 2 radios, but I don't know if I can send GPS position from one to the other, and how can I do that.
Then I need to know The format of the message sent.
I don't understand what are you asking "Are you trying to get the GPS off the air, or out of the base end radio?"
This radios has the GPS power on automatic by programming the codeplug.
best regards
daniboy
N
N_Jay
Guest
Yes is a MOTOTRBO.
best regards
daniboy
Motorola probably sells some equipment to get the GPS.
Josh
Auburn Hills, Michigan
It's pricey...
and also, I don't think the radios will send GPS data unit to unit, but rather portable or mobile to base radio connected to a computer with the GPS mapping software installed.
-Josh
daniboy
Ok, so I will check this info.
Motorola has a program to receive GPS data, but I think that iso not necessary. Maybe if I connect the base Station to the PC and check the Tx and Rx data I can describe the GPS data.
I will use a base Station connected to a PC and see what is appen. The I post here more info.
Best Regards
Daniel Pereira
daniboy
Hello again
so I tried to connect my pc with a base Station DM3601, but something is wrong.
My CPS (program software) works well with the DP3601, but give me an erro when I try read the DM3601.
Anyone knows what means this error? - "error #1164", and someone knows the rigth software that I can use to read and write this model?
best regards
Daniboy
