Just curious. If two units key up simultaneously on a digital system frequency or system, what will happen. I know on an analog system the two units usually make a buzzing noise and cut each other out.
You haven't tried LTR or PassPort...N_Jay said:Trunking systems usually don't allow doubling.
N_Jay said:You will get anything from some reduction in the voice quality of the stronger signal to complete cancellation.
Conventional systems do. Some radios can be programmed to prevent it.
slicerwizard said:You haven't tried LTR or PassPort...
SLWilson said:I'm sure that the actual patrol post dispatchers can "override" the bonk out feature, but, I'll have to ask to be sure...
Steve/KB8FAR
zerg901 said:Actually policefreak, I think you have stumbled onto something very profound. If a TRS could be set up to allow 2 field units (on the same talkgroup) to talk at the same time, that might be a very, very, very, useful feature.
policefreak said:although I guess two units could be trying to communicate on the same talkgroup and I bet that can cause some confusion!
zerg901 said:- radios that can receive and transmit at the same time. Like my $5 cellphone.
Peter Sz
zerg901 said:I am talking about putting a 2nd input freq into play when a double is about to occur. Field Unit 1 would transmit on Freq A - Field Unit 2 would transmit on Freq B - the infrastructure would allow everyone on the TG to hear both messages.
SLWilson said:Not sure if it is the "Programming" or what, but on the Ohio MARCS system, two radios will NOT key at the same instance. If one radio is "on the air" and another one tries to key, the second operator gets a BONK noise out of their radio.
I'm assuming if BOTH tried to key at the same time, one would be just a "little" quicker on the key & block the other one and get bonked.
Additionally, if you try to key while another radio is talking on your TG, when THEY stop, you get an alert to let you know the channel is NOW clear for you to use....
Steve/KB8FAR
