cookiegirl01us
- Joined
- Oct 31, 2013
- Messages
- 4
Looking to buy a digital police scanner what’s the best one any suggestions I’m looking for one you just enter zip code for easy setup thank you
Want to monitor police and fire 21502 is zip code looking for best scanner was looking at this scanner Whistler TRX-2where are you located (town, city, county, state)? what do you want to monitor?
Okay so you're going to need a radio that can handle Phase 1 and Phase 2 simulcast systems well. My recommendation stays the same, including regarding Whistler scanners. The best radio to handle Phase 1 and Phase 2 simulcast Distortion secondary to LSM is sds100 + 200 If you just want to put your ZIP code in and limit your range and listen. It's a big investment and you want to avoid disappointment. The TRX may not work well for you but you'll save the few bucks by not getting a better radio that will work properly for you. Depends what your priorities are. You did say you wanted the best scanner for your area? Again good luck.Want to monitor police and fire 21502 is zip code looking for best scanner was looking at this scanner Whistler TRX-2
We must both have dyslexia. You made the same mistake I did and entered 21052 at Fort Howard in Baltimore County. 21502 is Allegany County MD which largely uses the FIRST statewide trunked system. FIRST uses simulcast sites and I have problems monitoring the statewide system with anything other than a SDS100 or SDS200. The Uniden SDS100 handheld and SDS200 base/mobile are the only scanners designed to receive simulcast systems.Haha, when I looked up that zip code I got Baltimore County Maryland.
Yep, I did make the same mistake Jim LOL. We are not hearing much from the original poster but I think the point here has been made very well.We must both have dyslexia. You made the same mistake I did and entered 21052 at Fort Howard in Baltimore County. 21502 is Allegany County MD which largely uses the FIRST statewide trunked system. FIRST uses simulcast sites and I have problems monitoring the statewide system with anything other than a SDS100 or SDS200. The Uniden SDS100 handheld and SDS200 base/mobile are the only scanners designed to receive simulcast systems.
