I'm a newbie at antenna-building
I have googled and searched this forum for answers, but didn't find anything conclusive.
Does a dipole have a 'right side up' ?
Or can either of the 2 pole-elements be the pole that hangs upwards/downwards?
I constructed a dipole for civil airband out of aluminum tubes, but didn't think about orientation when I soldered the connections.
This means I don't know which one of the 2 tubes (The dipole elements) goes to lead-in (On the radio-receiver's antenna-input) and which one goes to 'ground-in'.
I read that with monopole-verticals, you want transmitter and receiver to be the same orientation (Either both are upside-down, or both are rightside-up) to avoid phase-issues.
However, I am not sure if this is significant with dipoles (If a signal is received stronger or more faint, depending on the receiver dipole's orientation)
I attached some pictures of the tube-antenna I created.
It seems to work well, but now I'm wondering if a dipole can actually hang 'upside-down' and how that may affect reception (Weaker signals, stronger signals)
I can't really turn it upside-down to experiment, as the hooks it's hanging on only works one way (The way it's currently hanging on the horizontal black rod)
Thank you.
jacob.
Thank you.
jacob.
