"discona" antenna
Osiris007
Hello, how can I hold and secure the radials of a "discona" antenna so they don't come loose and fall into the street? Thank you.
paulears
Lowestoft - UK
Locktight doesn't complete cover the threads - just a tiny dab on the final few. To be honest I have never bothered. The metal oxidises once outside, and I always have to heave with a spanner to get them undone after just a few months. Never had one on any antenna unscrew and fall out of properly done up.
Osiris007
Is there any threadlocker that conducts electricity so that the radials do not lose contact when applying the locking agent?
kc2asb
NYC Area
Every antenna I've assembled and mounted with radials had nuts that could be tightened up with a small wrench/spanner, including a discone antenna from Radio Shack. I never had any radials fall off, even through heavy wind storms.
If you are concerned, you can check the antenna periodically, especially after storms, and make sure everything is tight.
dave3825
Suffolk County NY
Not sure how it compares to thread lockers, but there are conductive epoxies.
K4EET
Chaplain
Severn, Maryland, USA
Do you have a manufacturer and model number for the discone antenna? Maybe we can pull up an assembly manual to see how your antenna is made. That might give us some additional ideas on how to secure the radials.
paulears
Lowestoft - UK
I can 100% assure you that if you tighten the radials with a spanner, the damn things won't come undone - the diamond hardware goes powdery very quickly. I took an old diamond down after 7 years and no way were those radials coming out!
GadgetGeek
Bergen County, NJ
Agreed.
I'm using the same antenna. No locktite.
K4EET
Chaplain
DIAMOND D-130 DISCON ANTENNA (ORIGINAL JAPAN)
I have that antenna…
In addition to the nut on each horizontal rod, my “design” includes a stainless steel lock washer between the base and the nut. I also put a tiny drop of red Loctite on the nut threads. Note also that these rods MUST be installed after the sloping radials are installed.
For the sloping radials, which are to be installed first, make sure that the filed end lines up with the set screw. For the set screw, which needs to be securely tightened, I also added a drop of red Loctite.
The Loctite will not hinder the rods (elements) or radials conductivity to the overall assembly. Like others have said above, using no Loctite should work just fine due to the oxidation of the metal. I used red Loctite to insure things never loosen unless a propane torch is used to heat up the item to be disassembled.
wtp
Port Charlotte FL
in 1975 my electronics teacher said after screwing stuff in, use your sisters nail polish.
it might be the same firmness as the light locktight.
by the way, locktigh comes in different strength.
some you have to heat to red hot, some are like nail polish.
and if done after screwing them in you don't have to worry about the connection.
Osiris007
In the DIAMOND S130 antenna, when the longer radials are inserted into their hole, the smooth part has to remain horizontal so that the screw grips it, or it has to remain vertical...
Ubbe
Stockholm, Sweden
You don't need electrical contact from radials.
Even any small distance from isolating lock-tite would not be of such a low capacitance that it will matter.
/Ubbe
