gregpawlak
I rent a place on the second floor of a 3 story house. I want to get a discone antenna for my
An antenna doesn't care of a signal is digital, analog, data, etc. Focus on band as opposed to voice mode when it comes to antennas. Only you'll be able to answer the question if it will "be enough" as everyone's monitoring environment is unique. Will performance be on par with an outdoor antenna mounted high? Depends on how close the stations are you're monitoring. Experiment with it, have fun. Welcome to the forums!I can't put it outside because of landlord request, but I can install it inside and raise it as high as my ceiling, which is as high as I can get. Will that be enough, and will the antenna also help with digital signals? The law enforcement in my area use digital, while emergency communications are still analog.
Well that's the thing, I have a decent whip antenna on my handheld, and it picks up a lot around me including aircraft, but all law enforcement here use digital, so my old scanner is analog and you hear that 'brrrr', so I upgraded but want to make sure the discone will work better than the whip as far as pulling in signals. Like i stated i can't put it outside due to landlord problems, but being up on the second floor i should at least be high enough to use it indoors. I just want to be sure im not throwing money out the window.The important issues are:
- can your antenna "see" the antenna of the signal you want to receive?
- you want "line-of-sight" with as few obstacles as possible
- make sure the coax from the antenna to the receiver doesn't lose 'too much' signal.
Yeah, there will be obstacles in the way, but keep to as minimal as reasonably possible. I like my antenna high just so it can see as far as it can over the curvature of the Earth.
I see people put up great antennas, even outside on their roofs; and then use cheap coax that loses more signal than they would have had with a rubber antenna connected directly to the radio. The higher the frequency you want to receive, the better coax you need. And don't make it longer than you absolutely need.
I think you may be.... I just want to be sure im not throwing money out the window.
Thanks!An antenna doesn't care of a signal is digital, analog, data, etc. Focus on band as opposed to voice mode when it comes to antennas. Only you'll be able to answer the question if it will "be enough" as everyone's monitoring environment is unique. Will performance be on par with an outdoor antenna mounted high? Depends on how close the stations are you're monitoring. Experiment with it, have fun. Welcome to the forums!
Perfect thanksYes a Discone antenna would be a great improvement over the rubber duck antenna you may be using now on your SDS100,try if you can to get it close to a window......
Should you decide to go with a discone (what it may lack in gain is offset by versatility), you might find this thread useful:I rent a place on the second floor of a 3 story house. I want to get a discone antenna for my
Uniden SDS100 scanner,
yeah this is what I have in mind. I already have the stand, I can go to Lowe's for decent coax, and I ordered the discone on Amazone should be here on Monday. thanks!Should you decide to go with a discone (what it may lack in gain is offset by versatility), you might find this thread useful:
Indoor Discone Antenna
Your Lowes has 50 ohm low-loss coax?I can go to Lowe's for decent coax
Hi GilliG40, nice to see you again. The issue im having is scanner only stops on about 4 different departments. I have many programmed.If you’re looking for one that works well for NWORPSS. I use a Remtronix 830B. I use one on my SDS200 and another one on my Unication amplified charger. Both are used in my basement. Definitely solved the issue of my G4 locking on the Wood County site. If you’re looking for a wider range antenna Remtronix also makes a Tri band antenna.
