Display Lines On 996
jimg
So. Middle TN
#1
Can anyone explain what the two groups of numbers at the bottom of the display represent or are for.
SQ: 1234567890
GRP: 1234567890
Thanks in advance for your help.
Plainfield, IL
#2
It shows which system quick keys and group quick keys are active. If they're turned on, the number appears. If they're off or not set up, you get stars. If they blink, they're being scanned or are active.
Eric
