Display Options
KO4IPV
Sentinel software settings when making a new favorites list/ using the SDS100, in display options what settings are a must do before write to scanner?
tvengr
Well Known Member
Baltimore County, MD
Display options are not in favorites lists. Each profile has its own set of display options. Go to the Tools tab select SDS100 as the Target Model. Go to the Edit tab and Edit Profile. Under the Display Options tab, make your choices. To customize the display on the SDS100, go to the Edit tab and Edit Display. The Edit Display option is available only if the Target Model is set to SDS100 or SDS200. Each profile has its own custom display settings. You can export your custom settings to a file and save them. When creating other profiles, you can then import those settings. You can also attach that file for others to use your custom settings or import custom settings from another member.
KO4IPV
As I said in my initial comment, when making a favorites list , there is no mention of the display option being in a favorites list Being that said, is there a must settings in the display option when making a certain favorites list ???
KO4IPV
Here is the display option in Sentinel
KO4IPV
The Decimal setting is what I am concerned about? Upon checking the database in my SDS 100 scanner after downloading into the scanner a new favorites list I see thatSome of the channels are listed as DEC or decimal do I need to change that setting in display options before writing to scanner
