SEQLD_SCAN
- Joined
- Mar 26, 2010
- Messages
- 15
- Reaction score
- 0
Hi all,
I run a 24/7 stream on radioreference.com
http://www.radioreference.com/apps/audio/?feedId=4450
The CTCSS tone on this stream is 107.2Hz. I have found it is quite audible when listening to the stream via my computer speakers, which have a subwoofer attached.
The subwoofer really makes the 107.2Hz stand out.
I looked for a software-driven equalizer but they are all too expensive or just don't work.
Overnight, I had a brainwave and thought about trying a passive high pass filter.
I put this simple twin-t circuit together in a spare DB25 backshell.
The socket and plug are held in place with hot-melt glue.
The component values have been calculated to give a deep notch at 108Hz.
This works brilliantly! Cost less than $4 in parts and only an hour of my time.
It connects between the scanners speaker-out socket and the PC's line-in.
The calculations and circuit diagram can be found here:
(Sample)Twin-T Notch Filter Design Tool - Result -
Cheers,
SEQLD_ SCAN
Cheers,
SEQLD_ SCAN
