DLR Series
Bobby_B
Longtime lurker, first time poster. I'm amateur/GMRS licensed and wanted a better solution to communicate with family and occasional business events. Threads from knowledgable posters in this forum and others pointed me towards the DLR/DTR series and I jumped in. I'm very impressed with these series of radios. I've been playing around with DLR1020s and they are great for the average user, so I went ahead and ordered a DTR700 for myself. I used CPS for the 1020s and it works fine though there were a couple of bugs (particularly any feature with radio names). I turned all the beep volumes to minimum and turned on beginning/end roger beeps. I noticed the beginning/open beeps only occassionaly happen. The ending beeps seem to be consistent. But, overall, great options in CPS to tweak the radio to the user. In my effort to better secure my comms, I have some questions:
- I've already changed my Profile ID to something other than "0000", and using Channel 2 (because I don't like to leave anything on default), but what exactly is a "Channel"? I know it's not a freq like in the traditional sense. Is it just a grouping function? Does it have any effect on the hopset used? Does it matter from an RF traffic perspective if 1000 radios are on Channel 1 and 0 radios are on Channel 2? If I'm understanding things correctly, the last digit in the Profile ID is the hopset used? I'm just trying to understand the value of channels particularly from a traffic and security perspective.
- Is there any way to make a private talk group that only allows radio IDs in my group to hear/talk among themselves? There's a built in feature to do one-on-one direct, but is it possible to set it up as a group? I know these radios are pretty secure through obscurity already, but just thinking if there's a way to increase it more.
737mech
Clark County, NV.
Yes you can. I have DTR 650’s and you can set them in a private group. Use the help tab in CPS so you get accurate info, my CPS might be slightly different. Just pay attention to private groups not public groups. Each radio gets entered as a private entry then below that create a private group. You should see a list of your radios from private and drag them over to the group box then select a different channel and your done.
Bobby_B
It seems the radio name issue is related to a Microsoft Speech Engine issue. I’m going to try and upload a .wav instead.
I’m able to create private groups with all the DLRs added in CPS, but it doesn’t seem to work when I assign it to a channel. Curiously, I am able to assign a private direct talk to a single radio on a channel - that worked. It just doesn’t like the private group. Not sure what I may be doing wrong.
n1das
Nashua, NH
You might have read some of my posts in other threads. :)
Regarding the beginning/open beeps, these beeps indicate the start of an incoming public group call or private call. These calls have a hang time associated with them. The next incoming group or private call beep will not occur until the start of the next incoming group call or private call received after the hang time expires. The default group call hang time is 4 seconds and the default private call hang time is 10 seconds. The public group call hang time affects how much time you have to activate the 1 button Private Reply feature after the last received public group, private group, or Profile ID group transmission ends. The Private call hang time affects how long the radio hangs in 1 to 1 private call mode. In the DLRs, this is marked by a "Private" voice message at the start of a private call and ends with a "Private Over" voice message after the hang time expires. In my DTR700 fleet and previously owned DLR1060 fleet, I lengthened the group call hang time to 10 seconds and left the private call hang time at the default of 10 seconds. This gives me a little more time to hit the private reply button after receiving a transmission. You can also hit the private reply button while hearing a transmission if you want. You don't have to wait until a received group call ends before setting up a private reply.
The start of an incoming call beep on the legacy DTR410/550/650 is an annoying DEE-DEET double beep, consisting of two 90ms bursts of 2300Hz. The group call and private call hang times are 12 seconds long and are not adjustable.
The end of transmission "roger beep" in the DLRs and DTR600/700 is a soft DEE-DOOM sound. With the legacy DTR410/550/650 radios, this is a 40ms beep at 2300Hz and the volume is not adjustable but is linked to the radio's volume setting. The legacy DTR's roger beep can be annoying at times and it cannot be disabled. I've played around with the roger beep feature on and off in my DTR700 fleet and I ended up just leaving it off. I like peace and quiet at the end of a received transmission. The default setting is OFF.
I recommend not using the start of group call beep. This is a soft DOOM-DEE sound, the reverse of the end of transmission roger beep. I've found it causes the receive audio to "stutter" once at the start of an incoming group call. For example, if you press PTT on a DLR or DTR radio and say "Hello" immediately after hearing the PTT chirp, you will get "Hello-ello" coming out of a DLR or DTR600/700 if the start of group call beep is enabled. The rest of the received transmission after about the first second will be normal. This weird behavior I noticed with the start of group call beep enabled. The default setting is OFF and I recommend leaving it off.
Regarding channels, a channel is grouping function. It is not a channel in the traditional sense of a conventional radio. It has no effect on the hopset used. The end user sees channels but they are talkgroups used on a hopset. A channel has multiple modes available: Profile ID group, public group, private group, and private 1 to 1 call. The DLRs can do 1 to 1 private calling like the DTRs but requires the CPS to set up. With the DLRs, it's not worth setting up a 1 to 1 private call because it wastes a channel and there are very few channels available. The DLRs also don't have a display to be able to select a private contact from a list of contacts and have no way to scroll through contacts. With the DLRs you are better off to use the 1-button private reply feature for 1 to 1 private calls and use the channels for public and private groups or Profile ID groups. Initiating a 1 to 1 private call is better done in the DTRs than the DLRs.
Groups (public/private/Profile ID) are set up in the programming and then you map each group to a channel, similar to other Motorola radios where you assign a conventional radio personality to a zone and a channel.
The legacy DTRs showed talkgroups to the end user instead of channels. In the legacy DTRs, channels referred to the 10 hopsets available. Motorola cleaned up the nomenclature in the DLRs and DTR600/700 models to make it easier for the end user. Hopsets are simply called hopsets because that's what they are and these are transparent to the end user. The concept of a channel like in a conventional radio is easier for the end user to grasp than a talkgroup (WTH is a talkgroup?). The DLRs and the DTR600/700 appear more "channelized" to the end user than the legacy DTRs. They are backward compatible with the legacy DTRs but program a little differently.
The 4 digit Profile ID Number (PIN) feature is a new feature that started with the DLRs and was carried forward to the DTR600/700 models. The legacy DTR410/550/650 models don't have any Profile ID features. The PIN modifies the group ID and hopset used for the first 20 public groups. It gives another range of available group IDs to use and is used for making groups more secure than public groups but not quite as secure as a private group. The PIN feature makes it insanely easy for users to take a group of radios right out of the box at the factory default settings and secure them without needing the CPS. Just set the PIN from the keypad in programming mode to match in all radios and you are done. The legacy DTRs required the CPS to set up anything private. The PIN feature also added Page All Available and Call All Available features which are all-call features the legacy DTRs don't have. Profile ID groups are compatible with the legacy DTRs when the PIN is at the 0000 default. Profile ID groups are public groups when the PIN is at 0000 because the PIN feature is OFF.
You are correct in that the last digit of the PIN affects the hopset used by the radio. It also affects the whole radio. On the ADVANCED page in the CPS, you can disable the Profile ID Number Lock setting to change the hopset if you want. The default is ON. The CPS warns that disabling the lock may cause some features to not work and is recommended only for experienced users familiar with the DLR/DTR protocol. If all of your channels will use the same hopset, I recommend leaving the Profile ID Number Lock ON and choose a PIN carefully so that the last digit matches the hopset you want to use. Hopset #1 is the default hopset used and is identical to the legacy DTRs.
Private groups in the DLRs and DTR600/700 models program and function identical to Private groups in the legacy DTRs. The 11-digit private ID of every radio in the group has to be programmed into every radio in the group. The CPS is capable of reading the private ID from individual radios. The legacy DTRs were capable of reading the private ID from another DTR radio over the air with the CPS. These features make it easy to capture the private ID from radios in your fleet.
Public groups in the DLRs and DTR600/700 models program identical to public groups the legacy DTRs but with a small twist to be aware of. The DLR/DTR protocol has a restriction that each group ID can be used only ONCE in the radio. The Profile ID features take up the first 20 public group IDs. Plain old public groups identical to the legacy DTRs are then forced to start at ID=21 instead of ID=1. Note that this is the case only when the 4-digit PIN is at the 0000 default. When the PIN is at the 0000 default, the Profile ID mode for channels is OFF and the first 20 Profile ID groups ARE public groups identical to the legacy DTRs. Group IDs 19 and 20 are reserved for Page All Available and Call All Available features and are labeled as such. More about these features below. When the PIN is set to a non-zero value, Profile ID groups are no longer public groups and IDs for public groups start at ID=1 instead of 21, identical to the legacy DTRs. I recommend setting the PIN to a non-zero value even if you are not going to use any Profile ID features, taking care to choose a PIN carefully such that the last digit matches the hopset you want to use. This is the way to program public groups when you have a mix of public group, private group, and Profile ID mode channels.
The Profile ID features added Page All Available and Call All Available features. These are ALL CALL features to call all of your users even if they may be on different channels, i.e., on different group IDs but all on the same hopset. It saves a caller from having to call a user on each individual channel to find them like they would with a conventional radio. Call All Available calls all users that are not currently in a call and throws them all into a temporary supergroup with a 4 second hang time. All users in the group can chitchat back and forth on this group provided they don't let the 4 second hang time expire. The 1 button private reply button is disabled in this mode, IIRC. After the 4 second hang time expires, all radios revert back to the individual group(s) they were previously on. Page All Available works similar to Call All Available in that it throws all responding radios into a temporary supergroup with a 4 second hang time but PTT is disabled and a user can reply using the 1 button Private Reply feature. Since the Private Reply feature is for 1 to 1 private use, only a single user can respond to a Page All Available call. All other radios revert back to the group(s) they were previously on after the hang time expires. Page All Available is useful for paging a group of users even if they are on different channels (groups) and allows one user to respond privately.
Another reason I recommend setting the PIN to a non-zero value is to prevent your radios from being trolled by others using the Page All Available and Call All Available features. These features requires a matching PIN in order to work. DLRs and DTR600/700 radios will respond to Page and Call All Available from other radios when the PIN is at the 0000 default. It is possible for a group of users with defaulted DLRs or DTR600/700s to get trolled by someone using Page All Available or Call All Available. The group of users then change channels to try to get away from the troll but they still hear the troll. Then they try all channels but to no avail because the troll is using Page All Available or Call All Available. These features can be used to ph*ck with other users. Setting the PIN to a non-zero value will prevent this from happening. The Profile ID features are neat and useful features that were added to the DLR and DTR600/700 models but they expose a vulnerability that users concerned about security should be aware of. I wish the DLRs and the DTR600/700 included an option to disable the Page All and Call All Available features.
The legacy DTRs don't have the Page and Call All Available features but they can trigger the Page and Call All Available features in defaulted DLRs and DTR600/700 radios. Group IDs 19 and 20 are used for Page All and Call All Available in the DLRs and DTR600/700 radios. These IDs are normal public group IDs legacy DTRs. DLRs and DTR600/700 radios interpret these IDs as Page All Available (ID=19) and Call All Available (ID=20) and respond accordingly. Setting the PIN to a non-zero value will prevent your DLRs and DTR600/700 radios from being trolled by legacy DTRs using public group IDs 19 and 20.
These are excellent radios and people keep underestimating them.
n1das
Nashua, NH
What 737mech said. Yes you can!
I have Private Groups in my DTR700 fleet working with Private Groups in my DTR650 fleet. I previously owned a DLR1060 fleet and also had them working in a Private Group with my DTR700 and DTR650 radios. I have had them all working with each other on public and private groups. I also had the DLRs working with the DTR700s on Profile ID mode channels. The legacy DTRs don't have the Profile ID features.
The latest Motorola Business Radio CPS is R07.02. The DLRs and the DTR600/700 models are fully backward compatible with the legacy DTR410/550/650 models. They program a little differently than the legacy DTRs but are backward compatible.
Private groups in the DLRs and DTR600/700 program identical to private groups in the legacy DTRs. What's different in the programming from the legacy DTRs is you map each group to a channel similar to assigning a radio personality to a zone and channel in a conventional radio instead of making groups appear in a scroll list. The DLRs and DTR600/700 models behave as channelized radios similar to a conventional radio and don't have a scroll list.
DLR1020 has 2 channels and cannot be upgraded.
DLR1060 has 6 channels and radios built after mid-2017 can be upgraded to 10 channels with R05.01 or newer CPS. The DLR1060 is still marketed as a 6 channel radio.
DTR600 has 30 channels.
DTR700 has 50 channels.
The latest firmware for the DTR60/700 added the remote monitor and manager mode features the legacy DTRs have. I have tested the manager mode features in my DTR700 fleet with my DTR650 fleet and they work with each other. The firmware also added scan capability like the legacy DTRs. The first FW release for the DTR600/700 models did not have scan capability or manager mode features. I upgraded the FW in my DTR700 fleet to get all of the features. Recent builds of the DTR600/700 models should already have the latest FW.
n1das
Nashua, NH
DTR signal on spectrum analyzer looking at the 902-928MHz band:
My wife and I were at a hamfest in NH in 2017 and had someone seriously try to listen us and failed of course. My wife had gone to one of the food vendors to get some lunch while I was still wandering around the fairgrounds. We were talking back and forth on our DTR650s as she was trying to find out where I was so we could meet up. Since she was by herself at the time, a guy at table asked her what frequency we were using. Since she didn't know, she asked me over the radio and said someone at a table was asking her about it. I replied that they are digital radios operating on the 902-928MHz band and using FHSS. The guy said to her "Ohhh...so THAT's why I can't find you on my spectrum analyzer!!" LOL. He was expecting to see a strong narrowband signal popping up in the usual spots in the UHF band. We were hiding in plain site with other FHSS stuff transmitting in the 902-928 MHz band. As soon as he realized we were using FHSS digital radios he knew he wasn't going to be able to listen to us at all.
Bobby_B
I figured out what I was doing wrong with the private group. I needed to create a Private Group “radio” as a contact using a made up ID, and assign that to a channel. Now the private group talk seems to work.
So from a security standpoint, is a private group about the best that can be done outside of true encryption? It seems like getting through the front door is impossible unless one knows the private group ID AND spoofs the ID of a group member?
Thanks for the opening beep note. I did notice that stutter after you pointed it out. I turned it off. I also tried turning on the more treble option and it does seem to clean up voices especially if one has a deep or muffled voice.
n1das
Nashua, NH
You need to name the group and then assign it to a channel. Glad you got it figured out. I find the DLR and DTR600/700 programming to be more straightforward than programming the legacy DTRs. The legacy DTR410/55/650 models are more cryptic to program.
I recommend enabling the Treble option in the DLRs. It helps clean up the transmit audio and makes it more crisp sounding. DTR600/700 models don't have the Treble option but have better audio thanks to Motorola adding AGC to the transmit audio. The DLRs and the legacy DTRs don't have any AGC in the transmit audio. With the DLRs I found it best to leave the mic gain at the default (medium setting) and talk normally and about 1-2 inches from the mic. I've had to remind users of my DLRs to be careful with that. Talking loudly or climbing up on the mic can cause the DLRs to transmit very badly distorted audio due to no AGC. I have tried setting the mic gain down to the Low setting and I found it helped with distortion but the audio was so low that it was unable to drive another radio to full volume. I found it best to leave the mic gain at the default (medium) setting and enable the Treble option and be careful when talking into the radio. I want Motorola to add AGC to the DLR transmit audio like they did with the DTR600/700.
Private 1 to 1 calling is the most secure of all, accessed by the 1-button private reply feature. The two radios talking to each other in a 1 to 1 private call will not hear or talk to any other radios. Other radios will not hear or talk to a radio that is busy in a 1 to 1 private call.
The DLRs and DTRs use an ID-based system. With a private group, the private IDs of all radios in the group have to be in all radios in the group for it to work. In a private group, a radio only responds to incoming private IDs that are members of the private group. With a public group, a radio will respond to any incoming private ID with a matching public group ID.
The 11-digit private ID in each radio is similar to a hardware electronic serial number (ESN) and cannot be changed by the end user or with the CPS. I have never heard of anyone spoofing the 11 digit private ID in a DTR or DLR radio.
The 4 digit Profile ID Number (PIN) and the Profile ID features makes it insanely easy to take radios right out of the box at the factory default settings and make channels secure by setting the 4 digit PIN. No CPS is required. This makes it easy when replacing radios or adding more radios to an existing fleet. The private IDs of each radio in the group does not need to be programmed into each radio. Assuming all radios are at the factory default settings, just set the 4 digit PIN in new radios to match what the fleet uses and you are done. These channels are Profile ID mode channels. While Profile ID mode channels in general are very secure, they are not quite as secure as a private group in that another radio with a matching Profile ID (1-18) and matching PIN can join the group.
With the legacy DTRs, the only way to make groups secure is to create private groups with the CPS. The legacy DTRs will talk to each other right out the box at the factory default setting on the default public groups. The CPS is required to create private groups as there is no way to create a private group without the CPS. A private group is also a PITA when replacing radios or adding radios to an existing fleet. The private ID of all new radios needs to be added to all radios in the group and the IDs of older radios need to be added to the new radios. A private group requires the private ID of all radios in the group to be programmed into all radios in the group. The legacy DTRs and the DTR600/700 have some OTA capability to update the contact list (private IDs) in each radio over the air. In general, private groups are very secure but are a PITA to maintain when replacing radios or adding more radios to the group.
The ID of a private group is formed from the 11 digit private ID of one of the radios in the group. It is supposedly possible for a radio outside the group to monitor a private group by adding that ID as a contact and creating a private group with that ID. From what I've read, the radio supposedly will be able to monitor the private group but won't be able to talk to it. I've never tried this but others supposedly have run into this when managing multiple fleets of DTRs. A thought I had was that it is possible for someone to monitor activity from a group of users on a public group with a DTR on the same public group and pay attention to the 11 digit private IDs that show up. If the users also have a private group in their radios, one of those private IDs that show up potentially is the ID of a private group in those radios. You could then try creating private groups from those IDs and see if you can hear anything on those groups if the users switch to their private group. If you want to prevent private IDs of your radios from being displayed on DTR radios outside your group, don't use any public groups and only use private groups or Profile ID mode groups.
I love these radios more and more as I continue to learn more about them.
Bobby_B
What I did incorrectly the first time when setting up the private group was letting CPS create the private group which defaulted to using that particular radio’s ID as the private group ID. I repeated that for all the radios so all of them were trying to talk to a private group that had their own radio ID (so nobody was on the same private group ID). I can see how if I used the same ID of any individual radio for the private group ID, and set all the radios to use that private group ID, it should work, though that’s not what I did. I created a new contact in the private list and made up a random 11-number ID. I then set the private group ID to this ID, and linked it to a channel. I then repeated that for all the radios using the same 11-number ID I originally created. This worked. So it seems one can create a random ID for a private group that doesn’t necessarily match an ID of the radio group. For security purposes, that suggests the only way to get in the front door would be knowing what the private group ID is. Does this suggest a more secure setup than the profile ID method? It would be an 11-digit vs 4-digit job.
Bobby_B
So I played around with some settings and discovered that if an outside radio has the Private Group ID, but no ID of radios in that group, it doesn't allow Tx/Rx inside. This seems like a pretty secure front door comms scheme. An outside radio needs to have the 11-digit Private Group ID and individual 11-digit radio IDs to communicate. Likewise, in-group radios would need to have the outside radio's ID programmed.
The Profile ID scheme is very convenient at the expense of 'some' security. I see that scheme like having a 4-digit password protected group. Any radio can Rx/Tx with the group if they have the password without the need to reprogram all the individual radios inside the group.
Marine_Cotporal
Simplex Kid
The more I read about the DLR, the more I’m interested. I’m trying to understand some things said here but am not totally there yet.
So my question. DLR 1020 vs 1060. One has 2 channels and the other 6. I would want to only utilize it for myself and the wife and possibly another radio. One upstairs and one downstairs in the house and one for me. I would like to do the private function or shall I say the almost private function where no other radio can tx or rx in. Can that be done with just the 2 channel DLR 1020? I would have no use for other channels. I only need one semi secure channel for the wife and I with only a few radios.
Bobby_B
While I'm not an expert, my understanding is yes, the 2-channel DLR1020 would work fine for you. Once you setup your private group on one of the channels, the other channel(s) are just a convenient way to switch nets for other purposes. As my application is similar to yours, I got the 1020s. I'd go with whichever you can find cheaper.
It's a little confusing to me why Motorola released two versions of the DLRs and DTRs. The only difference that I can tell is the number of channels, which is limited by firmware. I'd think the hardware is identical for manufacturing purposes. I suppose there's marketing value in offering perceived "options" and making it seem like the 1060s and 700s are "higher-end".
n1das
Nashua, NH
Offering more than one model plays into the psychology of having a choice by offering good/better/best options.
The DLR1020 is the cheap model ($209), offering 2 channels and no ability to expand the number of channels.
The DLR1060 for $10 more ($219) has 6 channels as factory default and units built after mid-2017 are expandable to 10 channels with version R05.01 or newer CPS. The latest CPS version is R07.02. Aside from being limited to 2 channels, the DLR1020 is identical to the DLR1060. The DLR1020 will do Private Groups identical to the DLR1060 and the DTR models.
The CPS is a free download from Motorola and the HKKN4027A CPS cable is around $36 on Amazon.
I recommend getting the DLR1060. I previously owned a small fleet of DLR1060 radios and the Multi-Unit Charger (MUC) for them. I sold them to a friend for his business after I got my fleet of DTR700 radios and the MUC for them. At first my friend wasn't sure what he was going to use the DLR1060 radios for, maybe to use them as rental radios for his customers. Now he and his employees use them all the time in and around the office and at jobsites because they work so well for on-site small business use...exactly what they were designed for.
Bobby_B
What could other channels be used for if one is using a few radios for local comms in a small group? I don't know what I'd use a second channel for. I can't imagine I'd even use it for a side conversion in such a small group, and direct-reply is already built-in if needed.
Bobby_B
To echo a comment n1das made, you’ll need the CPS programming cable and a PC to setup a private group in radio. Otherwise, pretty much everything else can be setup from the radio’s built-in announced menu system.
Without a programming cable, you could alternatively use the “Profile ID” security scheme which seems almost as secure/obscure as well. Just pick a 4-digit number, set all radios to that, and you’re done.
n1das
Nashua, NH
Having multiple channels available offers flexibility in channel configurations for different use cases. I have multiple channels programmed because of friends who use DLR1060 radios (previously was my fleet of DLRs expanded to 10 channels) and we use them publicly (on the default public channels) and also on private channels. The 4 digit Profile ID Number (PIN) is set to a non-zero value with the last digit = 1 so the default hopset (#1) is used. The first 6 channels are the 6 default channels in the DLR1060 but are programmed as public groups with IDs 1-6 to be compatible with defaulted DLRs and legacy DTRs. Two additional channels are programmed as public groups with IDs 19 and 20 to initiate Page All Available (ID=19) and Call All Available (ID=20) in defaulted DLRs but they can't do that to ours (unless the correct PIN is used). Two additional channels are private channels.
As Bobby_B mentioned, this is the fast and easy way to take DLRs right out of the box at the factory default settings and secure them without needing the CPS or cable and start using them right away with all channels secured. Motorola made it insanely easy with the DLRs and the DTR600/700 models. The legacy DTR410/550/650 models (discontinued a year or so back) always required the CPS and cable to setup private groups to make them secure.
