Dm5r programming for scanner use only need help
Jgevans
I have a real dmr radio that i was having issues with trying to receive all conversations. It would hear people talk and then miss their second reply. I found the setting for that radio. Now im trying to get the dm5r programmed with the software. Of course the setting have different names then my other radio. Does anyone know how to get all conversations with dm5r? Im only using it as a scanner not for repeaters. This pertains to dmr not analog reception. I have the cc, group, correct but there seems to be a timing issue. All transmissions are tier1.
rgchristy
Delco, PA
We need to know what version of DM-5R you have.
Version 1 DM-5R, Ver 2 DM-5R Plus or Ver 3 DM-5R with 1024 channels.
KE5MC
Lewisville, TX
One timing issue not fixable is the speed the radio will scan. Compared to a purpose built scanner handheld transceivers are turtle like getting from one programmed channel to the next. Thats one reason for missing parts of conversation, getting to the next signal.
Another issue which is fixable is how does the radio know when to continue scanning. I'm not sure if your radio address this per channel or scan function which would applied to all channels.
In general to resume scanning they are,
1. Loss of carrier, immediately resume
2. Hold on carrier for ?? seconds then resume (possible that conversation will be cutoff if long winded talker)
3. Hold on channel for ?? seconds after carrier is loss then resume.
Option 3 will allow you to hear both side of the conversation allowing for the 1-3 second transition from one talker to the other.
I hope that helps.
Mike
Jgevans
The first version and the PLUS but i think they all use the same software. This is a programming setting probably in the software. There are some settings in the main radio section but i dont know what they do, there is no manual for the software. This monitoring issue relates to only one frequency. Multiple people using frequency only every other conversation heard it is a timing issue or something. On my other dmr radio i fixed this issue by turning on slot suit (whatever that is) and ent type (whatever that is) i have no documentation because neither radio has any. Both of those settings were under channel menu.
rgchristy
Delco, PA
Here's the link for the user manual, programming software and password:
Baofeng DM-5R: Manuals and Software | QRZ Now – Amateur Radio News
First I create the contact (Group ID).
Then create the group list and add the contact to it.
Then create the channel. You'll need to know the slot, color code and contact (which you created above).
Here's the link to the thread that has printscreens of one of my DMR channels.
https://forums.radioreference.com/b...dm5r-plus-programming-help-advice-needed.html
The thread also has some programming tips.
Check it out and let us know if that helps.
Take Care,
Rich
Jgevans
Thanks for your reply, i have it set similar to the screen shot. Im only trying to monitor a talk group. I had to ask baoefeng to check into it. This is timming issue that does not allow all of a conversation to be heard. It may be the vocoder issue, but i wanted to check before i quit. If it is an issue with the vocoder no way to fix it. I was hoping the vocoder issue was only effecting repeater transmission but it looks like it may effect reception on tier 1 as well. I had the same issue with 2 other brands but hey had settings like tdma on, and slot suit on that fixed it.
