On the Uniden upgrade page, it says:
During conventional scan, when the scanner stops on a DMR transmission, the following information will be displayed:
DMR -- for DMR One-Frequency systems. The scanner will also display the current slot number (S1 or S2) and the received color code, if you selected Search when programming the channel.
CON -- for MotoTRBO Connect Plus systems. The scanner will also display the current slot number (S1 or S2) and the received color code, if you selected Search when programming the channel.
CAP -- for MotoTRBO Capacity Plus systems. The scanner will also display the current slot number (S1 or S2), the received color code if you selected Search when programming the channel.
DT3 -- for DMR Tier III Trunked system. The scanner will also display the current slot number (S1 or S2) and the received color code if you selected Search when programming the channel.
But when I scan what I believe is a Cap+ system with the "rest channel" behavior (no fixed control channel), i only see a "CC1" which I assume means Color Code 1, and not the aforementioned DMR system type. I know for sure it's a MotoTRBO system. Is there a display mode setting I need to select to get the protocol information?
