DMR Basic Privacy Compatibility Kenwood NX and Motorola Trbo
ces911
Hi all,
Is Kenwoods NX series Basic Privacy on DMR the same and compatibility with Motorola Mottrbo radios Basic Privacy ?
2154
They are not (one bit off). Mototrbo Enhanced Privacy is compatible with Kenwood NX-3xxx/5xxx enhanced encryption though!
RRR
OFFLINE
USA
Really? I have tried it every way possible, and still getting garble.
pewpew45
Make sure the key is labeled the same on both radios and in the same key slot. I have a xpr7550 and a nx-5300 talking together using enhanced ARC4 encryption on Dmr
wa8pyr
Staff member
Lead Database Admin
Ohio
Also make sure that one radio isn't using hex and the other using decimal. I ran into that issue with Motorola and Harris. Motorola uses hex, while I'm pretty sure everybody else uses decimal.
pewpew45
Good call, the Nx series radios use hex...
pewpew45
So which is it?
on my NX-5300 for ARC4/enhanced privacy I use the same exact code for the encryption. If using DES encryption motorola uses Decimal and Nx series uses HEX
2154
Yep. Using it on a whole fleet right now that's mixed between XPR7350s, XPR3x00s, and NX3300s. No issues. As the others said, make sure everything matches up.
wa8pyr
Staff member
Lead Database Admin
Ohio
As far as I know they're all looking for a hexadecimal string for the key itself, but make sure the key IDs match up. That's what tripped me up (Moto uses hex key ID, Harris uses decimal).
radioopperator
(M) enhanced encryption is also compatible with Hytera's encryption 10 bit I believe
kinglou0
Getting off topic but throw Anytone into the conversation.
It works but given my experiments with using enhanced encryption from the R7 down to the 6550, it’s not that great but i’m not complaining. Anytone throws it in as a firmware update. Makes me feel dirty…:cool:
Forts
Ontario, Canada
Agreed.... for me Anytone adding AES & ARC4 was just a very unexpected bonus (especially ARC4).
As far as BP goes, I've heard rumours that some of the off brand radios (BTECH maybe) were compatible, but for the most part... nothing is. It's Moto proprietary.
