DMR cap+ system using RAS or encryption?
So how can you tell if a dmr trunked system (cap+ in my case) is using such? I am getting a lot of "0" talkgroup and "0" user id showing up a lot, all with same cc and of course no audio. I also notice that the time slot keeps flipping back and both from 1 to 2 while its keyed up. Anyway all this happens whether the system is programmed in and scanning using id search mode or just using conventional search across the trunk freqs. However I do pick up an occasional conversation but very sparse at that. Should be a lot more traffic than that though and signal strength (reception) is not an issue.
So I didn't know if the 0-0 info was merely indicating telemetry data (it is a utility company) or something else.
Also--can such a system (site) support multiple color codes? I have noticed more than one color code. Didn't know the reasoning behind that.
Thanks a lot,
Sly
Thanks a lot,
Sly
