DMR Decoding
grp318
Does anyone have recommendations on deciding a DMR system?
I am currently using a DMR radio to only listen to a Motorola IP connect system. I would like to log the TS, CC and user ID. I have tried DSD+ and got poor results with my VR. I have also tried WinDSD but it’s not showing what I’m looking for. I like the stand alone idea of WinDSD and would not mind a program that allowed a line in from the radio.
Any ideas would be appreciated just shy of buying a scanner.
Thank you.
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Thank you.
Line-in? If you want to feed something to Line-In on your computer to then subsequently use a decoding app to decode DMR, you must provide discriminator audio. Unless you tapped the discriminator on your radio, the output from your radio isn't going to work.
Forts
Ontario, Canada
DSDPlus can't work miracles if it has to work with standard audio straight from a headphone/speaker jack.
No... 100% agree, but overall it's the best option. As also mentioned, grab and SDR dongle and away you go.
