DMR-MARC DSDPlus.radios File For DSD+
#1
I have created a DSDPlus.radios file for DSD+ that has all the DMR-MARC radio IDs with text descriptions. This is a current file with all the users as-of Saturday, December 10, 2016. I thought I would pass this along for anyone who would like to use it. This will allow you to automatically see the callsign, name, and location of whoever keys up.
Zippyshare.com - DSDPlus.radios
Barcelona, Spain
#2
Thank you very much for this. Good job. I hope you haven't done al this by hand...
At least with me, one thing happens though; after a minute or so of having DSDplus running, when the program updates and stores the .radios file, most of the text in every line gets shortened to the same 31 character size.
Here's an example (6 first line after DSDplus 1.storing)
DMR, 0, 721, 1106001, 50, Normal, 0, 1211/20/16 20:35, "KK6YLW - Robert L Garvin in Chu"
DMR, 0, 721, 1106002, 50, Normal, 0, 1211/20/16 20:35, "K6FED - Frank E Decuire in Ranc"
DMR, 0, 721, 1106003, 50, Normal, 0, 1211/20/16 20:35, "K6IJ - Frederic K Honnold in Pi"
DMR, 0, 721, 1106005, 50, Normal, 0, 1211/20/16 20:35, "KI6NRR - Brian Kunkel in Santa "
DMR, 0, 721, 1106006, 50, Normal, 0, 1211/20/16 20:35, "KI6NRR - Brian Kunkel in Santa "
DMR, 0, 721, 1106007, 50, Normal, 0, 1211/20/16 20:35, "KE6CQV - Gareth Harris in South"
Is it happening to someone else also?
Is there a way to fix this anyone knows about?
D
#3
No, not by hand, but with Excel formulas. Try widening the Event Log window. My text also gets chopped off at the end, but not as short as that.
Montreal, Canada
#8
Toronto, Ontario
#10
The script doesn't handle empty fields very well:
"PD0FEB: Dirk in , , Netherlands"
If $data[3] or $data[4] are empty, they and their following comma shouldn't be written.
BTW, for anyone who doesn't know how to run a script:
powershell -ExecutionPolicy Bypass .\DMR-MARC.ps1
(I named the script DMR-MARC.ps1 and changed the output file in the script from DSDPlus.radios to DMR-MARC.radios; that output file can be copy/pasted into DSDPlus.radios)
You can enter that command text at a command prompt or stick it in a .bat file.
Modified the script to deal with empty strings:
Code:
$database = "http://www.dmr-marc.net/cgi-bin/trbo-database/datadump.cgi?table=users&format=csv&header=0"
$csv = "datadump.csv"
Write-Host "Downloading database dump from DMR-Marc..."
Invoke-WebRequest $database -OutFile $csv
If (Test-Path $csv){
	$reader = [System.IO.File]::OpenText($csv)
	$writer = New-Object System.IO.StreamWriter 'DMR-MARC.radios'
	Write-Host "Converting database dump to DMR-MARC.radios"
	for(;;) {
	    $line = $reader.ReadLine()
	    if ($null -eq $line) {
	        break
	    $data = $line.Split(",")
	    $protocol = "DMR"
	    $id = $data[0]
	    $networkID = 0
	    $group = 712
	    $radio = $data[0]
	    $priority = 50
	    $override = "Normal"
	    *****s = 0
	    $timestamp = $(get-date).ToString("yyyy/MM/dd HH:mm");
	    $data[2] = $data[2].Trim();
	    $remark =  '"' + $data[1] + ': ' + $data[2] + ' in '
	    if ($data[3].length)
	    	{$remark = $remark + $data[3] + ', '}
	    if ($data[4].length)
	    	{$remark = $remark + $data[4] + ', '}
	    $remark = $remark + $data[5] + '"'
	    $writer.WriteLine('{0}, {1}, {2}, {3}, {4}, {5}, {6}, {7}, {8}', $protocol, $networkID, $group, $id, $priority, $override, *****s, $timestamp, $remark)
	$reader.Close()
	$writer.Close()
	Write-Host "Cleaning up..."
	    Remove-Item $csv
Else{
	Write-Host "Error: Could not download database dump from DMR-Marc."
natedawg1604
Denver-Metro
#12
Code:
	for(;;) {
	        break
	    $protocol = "DMR"
	    $id = $data[0]
	    $networkID = 0
	    $group = 712
	    $radio = $data[0]
	    $priority = 50
	    *****s = 0
	$reader.Close()
	$writer.Close()
	    Remove-Item $csv
Else{
I tried the script and got the following error message:
Missing expression after ','.
At ...\DMR-MARC.ps1:35 char:128
+ $writer.WriteLine('{0}, {1}, {2}, {3}, {4}, {5}, {6}, {7}, {8}', $pro
tocol, $networkID, $group, $id, $priority, $override, <<<< $*****s, $timestamp
, $remark)
+ CategoryInfo : ParserError: (,:String) [], ParseException
+ FullyQualifiedErrorId : MissingExpressionAfterToken
Toronto, Ontario
#13
Oh ****, RR is censoring *****s ("<dollar sign><hits>"). So much for not mangling code fragments.
I've changed *****s to $poops...
Code:
    for(;;) {
            break
        $protocol = "DMR"
        $id = $data[0]
        $networkID = 0
        $group = 712
        $radio = $data[0]
        $priority = 50
        $poops = 0
        $writer.WriteLine('{0}, {1}, {2}, {3}, {4}, {5}, {6}, {7}, {8}', $protocol, $networkID, $group, $id, $priority, $override, $poops, $timestamp, $remark)
    $reader.Close()
    $writer.Close()
        Remove-Item $csv
Else{
natedawg1604
Denver-Metro
#14
Code:
    for(;;) {
            break
        $protocol = "DMR"
        $id = $data[0]
        $networkID = 0
        $group = 712
        $radio = $data[0]
        $priority = 50
        $poops = 0
    $reader.Close()
    $writer.Close()
        Remove-Item $csv
Else{
Awesome, it worked! Incidentally, on my Windows 7 machine I had to upgrade from Powershell 2 to Version 4. Version 2 apparently won't support Invoke-WebRequest.
dave3825
New York
#15
I noticed that in Homeboys-Scanna screenshot that the target \ talk group is 3100. And in the file from tanilolli, the target \ talk group is 712. If I add these to my dsdradios file, will it display the users rid if he is not on tg 712 and say 3109? I thought I read somewhere that the dump file has about 70000 rids. Is there a dsdradio file that contains the 70000 rids?
#16
Aw man, I need to do another update on this file and post it for everyone. I can't remember how I did it, but I think I did some concatenating in Excel.
I believe the way it works is the radio ID alias will show no matter what conventional TG ID someone keys up on. If it's in the DSDPlus.radios file, then it'll be displayed.
dave3825
New York
#18
It seems to be working as I see names associated with talk groups other than what was entered into dsdradio file.
New DMR-MARC database file as-of 12/21/2017, Download it here, homies:
Homeboys-Scanna DSDPlus.radios file download, totaly free, totally awesome...
You don't have to replace your whole DSDPlus.radios file. Just copy and paste the rows into it.
Worked great. Thank you for the time and effort you took to do this..
#19
No problem. It is unfortunate that the DMR database is poorly designed as far as normalization and data integrity goes. Man, they did a crappy job and it's too late now to go back now and fix it.
