BCD436HP: DMR-MARC programming
Hudson, MA.
#1
How do i program the talkgroups for the DMR-MARC system? Do i enter as a One frequency system and use sites to store repeater frequencies? And the TG's use slots for different things so do I put the same TG twice with both TS occupied?
Bmacs
Southern NH
#2
Bagmouse has an excellent tutorial here:
http://forums.radioreference.com/un...mr-programming-single-channel-dmr-system.html
I just completed programming both the EWARN and the DMR-MARC repeaters in New England...
This is another VERY useful sight (NEDECN,org):
Index
Bill
W2SJW
Senior Member
Moderator
Northwest NJ
#3
I program the local affiliate system here in the tri-state area as an OFT. Each of the repeaters is a single-site with the proper color code assigned, and then I created a single department called 'DMR-MARC'. My talkgroup configuration is shown below:
