BCD436HP: DMR one frequency AGC
#1
If I set up a DMR as a conventional I can enable digital AGC but if I program it in as DMR one frequency, the option to turn on AGC is not there. I find that on DMR some transmissions are lower volume. I want to see if AGC corrects this.
Sent from my iPad using Tapatalk
