Hello all,
I have a Pro 668 that is had the Whistler factory DMR upgrade. My problem is I'm trying to listen to my local DMR hand repeater. No matter how I program the scanner whether I program DMR conventional or DMR trunking I can only receive one talk group. The talk group turns out to be on time slot to and is the only talk group on that slot. On time slot 1 there is five other talk group's and I never hear anything on them. I believe on programming it the right way as far as colorcode, time slot, and talk group's but I'm thinking there has got to be activity on the other talk group's at some time and I never hear any. There is anybody run across a similar problem?
Pete
You can't really go wrong programming a DMR frequency - even more so for amateur radio since it's a single frequency.
The simple method is a conventional DMR channel leaving everything set to "Any" or wildcard (*).
The better method for managing talkgroups is as a trunk system and this is only slightly more challenging - create a new DMR system, add/update a site with the repeater frequency, and add a wildcard talkgroup. You can leave all parameters like color code, etc. wildcarded/set to any.
Activity varies from area to area - when in central Maryland, I hear ALOT more talkgroups (worldwide, etc.) than in my current location.
Remember that some talkgroups are "local" and won't be heard unless you are monitoring the repeater that the users are talking on.
For comparison purposes - do you have some other radio or scanner at the same location that is receiving these other talkgroups?
