This should be the correct and active link to the latest Sentinel:
http://info.uniden.com/twiki/pub/UnidenMan4/DigitalMobileRadioUpgrade/DMR_Release.zip
By the way, it is linked to from my website (
Digital Frequency Quick Import).
If you've been using the pre-release DMR, your Sentinel might already be this version, but it does not hurt to update the Sentinel software just to be sure.
In the .Zip file that you download, open "DMR_Release" -> "BCDx36HP_Sentinel_Version_1_07_03.zip -> "BCDx36HP_Sentinel_Version_1_07_03" -> and finally double click on "setup.exe"
A window, "Welcome to the BCDx36HP Sentinel Setup Wizard" should open. Select "Repair BCDx36HP Sentinel" and then "Finish." If you don't have Sentinel or the newest version, it may ask you something different. Go ahead and install.
Launch the new Sentinel. Either use a card reader or connect via USB to your scanner and use as Mass USB storage. In Sentinel, go to "Update" -> "Update Firmware." You should see the SD card for your scanner listed. If not, investigate connection and click "Refresh." You can select a card then click "Info" to make sure it is the right one and to read information about your scanner, such as its firmware version and the electronic serial number. Once you are sure you have the correct card, hit "OK" and it will either update or alert you that you already have the current version. You might need internet access to complete this step. I am unsure.
Insert your microSD card in the scanner. Power cycle the scanner to complete the upgrade.
Acquire a DMR key for your product from Uniden.
myUniden - Customer Product Registration and Support Area
Once you have the key, do the following:
- Turn off scanner
- Turn on scanner
- Press "Menu"
- Use scroll wheel on left to go down about 15 spots until you find "Settings"
- Push scroll wheel to select
- Go down two to "Upgrade"
- Select "Upgrade DMR/MotoTRBO"
Enter the key including the dashes.
If you are unsure if your scanner is active for DMR, navigating to selecting "Upgrade DMR/MotoTRBO" will give you this message if it is active:
"DMR/MotoTRBO has already been activated.
Press any key "
After that, go to my website, download some frequencies for your area into Sentinel, transfer the list to your scanner, and you should be good to go.
