I am trying to listen in to a local utility company (WNH) who use a single DMR frequncy.
Using DSD+ fastlane, I've programmed the frequency into CC and I can see the green line become active when I assume there is a transmission. This coincides with a line popping up on the white line where the vertical frequncy placeholder is. DSD+ is run through a 1R.bat configuration. and the role is set as passive monitor. Raw Source audio monitoring is set to 0 (never monitor); Output is to my speakers with all digital voice synthesized; all protocols decoded; normal handling of group and private voice calls.
We I see the activity in the scope, I assume there's a transmission, but I get nothing.
I also have an SDS100 with DMR upgrade with the same frequencies copied over into a favourites list. I never hear anything, but I see when the talkgroup ID locks on with the text id, the slot #1 appears and I have full signal strength indicated. Utilities services is ON.
Is there something about the system I'm missing? Or have I the wrong settings in both monitors?
