DMR Talkgroups SL*
monitor_man
Hi:
Can someone tell me what an asterisk means when it follows SL in a DMR talkgroup?
Thx
mciupa
Canadian DB Admin
Moderator
I'm here a lot
It means that it is a Wildcard. In most cases, that is because it was unknown by the submitter to the database. Colour Codes must be populated in the database, talkgroups and slots can remain as wildcards until known.
monitor_man
I am looking at the University of Waterloo DMR frequencies. I have them programmed into my SDS200. They are being
scanned and I can see that it is receiving a signal but I only heard audio once. Uniden support cannot figure it out.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Which one of these are you interested in monitoring?
Frequency Input
License Type Tone Alpha Tag Description Mode Tag
461.02500 BMCC 8
TG 4500
SL *
UofW ParkingKitchener Campus Parking Control DMR Schools
461.02500 BMCC 8
TG 9000
SL *
UofW SecurityKitchener Campus Security DMR Security
164.10000 XNE931 BMUofW OpsWaterloo Campus Plant Operations FM Schools
451.01250 456.01250 VAY289 RMUofW AV SvcsWaterloo Campus AV Services FM Schools
463.96250 BMCC 8
TG 4500
SL *
UofW ParkingWaterloo Campus Parking Control DMR Schools
463.96250 BMCC 8
TG 9000
SL *
UofW EventsWaterloo Campus Security DMR Security
Have you also tried the Trunk System as well?
monitor_man
FrequencyInput
LicenseTypeToneAlpha TagDescriptionModeTag
461.02500BMCC 8
TG 4500
SL *
UofW ParkingKitchener Campus Parking ControlDMRSchools
461.02500BMCC 8
TG 9000
SL *
UofW SecurityKitchener Campus SecurityDMRSecurity
164.10000XNE931BMUofW OpsWaterloo Campus Plant OperationsFMSchools
451.01250456.01250VAY289RMUofW AV SvcsWaterloo Campus AV ServicesFMSchools
463.96250BMCC 8
TG 4500
SL *
UofW ParkingWaterloo Campus Parking ControlDMRSchools
463.96250BMCC 8
TG 9000
SL *
UofW EventsWaterloo Campus SecurityDMRSecurity
I am interested in monitoring the 4 DMR talkgroups. I did try the trunked DMR system and it doesn't seem to be active.
exkalibur
York, Ontario
They may not have omitted them. The system could be using pseudo-trunking in which case the time slot isn't fixed. Likewise if the system is Capacity Plus - the time slot is dynamic.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
monitor_man: Looking at previous submissions, when U of W Security was discovered in 2015, the submitter had Slot 1 listed. The next update was in 2017 where the talkgroups that are listed in the database were submitted as they appear in the listings. Perhaps you and those submitters could monitor these again and let us know of any changes that should be made to the database.
If no changes noted, then what excalibur said in post #6 is true.
monitor_man
I have been monitoring and receiving some audio. The various channels show 5 bars at times but there isn't always audio.
I am wondering if there are data bursts that show 5 bars. So far Wloo Campus security shows as slot 1 and Wloo parking
shows as slot 2. Kitchener campus security shows as slot 1. So far no action on Kitchener campus parking. I will keep monitoring.
Forts
Ontario, Canada
If it's anything like Western in London, there is very very little radio traffic right now as the campus is pretty much empty....
Heidi750
Kimberley, BC
Hi:
Thx
I hope it is OK to jump in here.
I use the BCD436HP and was also wondering about the asterisk... where would that go in the programming?
I thought it was only Search On or Search Off.
