If it is the control channel, it will never move off of it in conventional.
Don't recall if you've looked at this system with DSD+, but if you did, I suspect you'd see RAS in use and I wouldn't be surprised if that's knocking the scanner off the rails.
Looks like RAS is handled somewhat differently on DT3. [FONT="]Would you send me the Cap Max log with version 1.11.21? (not version 1.11.22)[/FONT]
CapMax CC at 1.11.21...
Can you conventionally monitor and advise if the voice is encrypted?
I believe that issue has been added to the bugs being fixed here:
https://forums.radioreference.com/u...x36hp-false-tgid-display-investigation-4.html
At least that is the most recently active thread involving UPMan and x36 firmware debugging.
