Al42: Look at the frequency in question, it is in the middle of a band where nobody who is going to be making an antenna and asking about a balun will be using it to transmit, so its kind of obvious that this antenna is for receiving. Yes, I am aware of the impedence mismatches already present and what using a balun will cause, but its a receive antenna so just connecting the shield to one side of the driven and the center to the other side should work sufficently for receive. Last time I looked because of the ranges of frequencies involved a typical scanner antenna impedence was from just a few ohms to several thousand ohms depending on frequency. Bill2k, your antenna will work for what you want it to without a balun, I have a 860MHz yagi I built that is somewhere around 4 ohms but works just fine, however its just a 3 element yagi. Bill2k, the 10 feet of coax will be helping you, at that frequency range coax loss becomes an issue with even short runs of coax so the shorter the coax the more signal makes it to the scanner.
