Do I need the usb cable?
Megahurtz
Does FreeScan work with the included serial cable, or do I need to purchase the usb serial cable? My PC does have a serial port.
captclint
Mountaintop, PA
If you have an older PC with serial port, you can use Freescan with included cable, If not, then a usb - serial adapter is needed.
