Docker Image
jegallag
Bel Air, MD
Does anyone know if there is a Docker Container of the with the Broadcastify Pi image?
If not, does anyone know how to create one?
Thanks,
John Gallagher
belvdr
No longer interested in living
Some things are just a pain in the rear to containerize or become massively large when done. I imagine this one would fall into that category, due to the various SDRs that could potentially be used. You'd be better served by creating one for your own needs.
jegallag
Bel Air, MD
I am new to Docker, fairly proficient on the Pi. Do you know of an easy to follow set of instructions on creating Docker containers from existing images on the Pi?
Thanks,
John
belvdr
Thanks,
John
It's essentially building the entire stack (selecting a base OS, installing applications, etc) in the image. A couple of examples are:
You can also have a source tarball you can copy into the image with the COPY command then extract it with a CMD. Be prepared for a frustrating experience, though. Some software becomes a real pain, especially if it needs access outside of a container, such as a USB device.
jegallag
Bel Air, MD
Thanks. I will look into this.
