Dodger Stadium + Los Angeles Coliseum DMR Systems listings now in Db
LAflyer
Global DB Admin
Moderator
SoCal
Today posted two new DMR systems in the database.
Dodger Stadium Trunking System, Los Angeles, California - Scanner Frequencies
Los Angeles Memorial Coliseum Trunking System, Los Angeles, California - Scanner Frequencies
You will note that while frequency information is likely complete, individual talkgroup information is limited.
It would be appreciated as additional talkgroups and their usage is identified that the information is kindly submitted so the Db listings can be updated.
For both facilities it would also be helpful if listeners can help confirm which if any of the existing analog frequencies listed in the Db remain in use potentially at each.
kma371
Fyi looks like the color code info on dodger stadium got lost when it was submitted.
Good additions to the DB!
LAflyer
Global DB Admin
Moderator
SoCal
Actually the color code on all 3 Dodger frequencies is supposed to be 0 (zero), but Db is still not taking 0.
I guess Lindsey still working on that known issue.
kma371
Oh ok, I thought when I saw this system in staging, it had different color code. It's showing 0 in the DB. Is it a scanner import issue where it doesnt' take it?
kma371
