HP-2: Does the homepatrol 2 pickup hex?
Zachvfd
I am looking at buying a HP-2 and my surrounding departments use hex as a Motorola talk group. Can you tell me how to program this to the homepatrol 2
CT
The database shows the Hex code too
Or just enter your Zip Code
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
You'd just have to convert it to the proper decimal value. It's a little further complicated because the "Motorola decimal" isn't exactly the same as the "Uniden decimal".
If your FD is on talkgroup 3BC for example, you convert that to decimal, which would be 956. (You can either convert that online or in a spreadsheet program like Excel, or in the Windows calculator in Programmer mode.) But you're not done yet. That value 956 is what Motorola radios would use to refer to that talkgroup, but Uniden uses a different range of numbers (long story but it's owed to a fairly old mode of trunking and how different activities on the talkgroup were received at that time). You need to multiply the value you got from the hex to decimal conversion by 16 to get the "Uniden decimal" value. So if you have a hex value of 3BC, the value you need to program into your scanner is 15296.
Hope that makes sense - if you want to post your talkgroups, feel free to do so and we can convert them for you.
tvengr
Well Known Member
Baltimore County, MD
Using HomePatrol Sentinel, you can set the TGID format to DEC or HEX under the Miscellaneous tab of the Profile Editor.
Zachvfd
Jay911
Hi, I actually missed an important point, and I apologize. Newer systems (APCO P25 systems) don't need that "multiply by 16" bit from my first email. Simply converting from hex to decimal is all you need.
In fact, the screenshot of your email has the channels in decimal value just to the left of the hex values. Motorola tends to preface them with an 8, which you can drop. So:
B321 = 45857
B322 = 45858
B323 = 45859
mc48
Monroe County, NY
Another option In Home Patrol Sentinel go to View>Motorola/P25 TGID format and select Dec. or Hex.
tvengr
Well Known Member
Exactly! Zachvfd, you must have missed my earlier post.
Zachvfd
Alright I got the software is their anyone that can help me program the scanner?
jonwienke
More Info Coming Soon!
VA
Start by scanning from the database. In most cases that will cover everything you want to scan, plus more that you don't. Once you have a better idea of what you want, copy the stuff you're intereste in to a favorites list. Don't try to program stuff from scratch. Reinventing the wheel is pointless, and very easy to screw up.
Zachvfd
Ok so I added the things I needed to the favorite list but when I hit write to scanner and everything goes to the scanner nothing happens
tvengr
Well Known Member
In your profile editor, make sure that the proper service types are enabled and that both Download and Monitor are On for the favorites list.
Zachvfd
So now that I’ve programmed everything I have heard every other department speak but the fire department any reason why it may be like this
