Figure I’d run this past the experts here. Friend of mine has a Laird 5/8 wave VHF 144-174 MHZ BB1443S on the way. It’s going to a Spectra that’s programmed anywhere from 150 all the way up to the WX bands. All RX only. He wanted to have this antenna cut and tuned for the 155ish MHZ since that’s where most of the frequency’s are in ( and also to trim it down so it’s not the full 49” in length ).
My local radio / Motorola authorized dealer said that with this particular antenna it doesn’t need to be cut or tuned at all since it’s rated for the 144-174MHz range. However - the specs on this antenna clearly say that it only has about 6mhz of usable bandwidth once it’s cut and tuned.
So I guess my questions are
1. - Does this antenna have to be tuned and cut just if it’s used as RX only ?
And 2 - if I do cut it to the cut chart ( which would put it at about 43 inches ) would it effect the performance for the higher WX frequencies ? Everything I read said when you cut the antenna it’s just basically dials in the TX performance and has nothing to do with RX only frequencies. So if it’s cut would it effect the other frequencies that are outside of that 6mhz ?
Thanks !
Thanks !
