download recordings from G5?
sirmouse
Ada MI
I'm in Kent County Michigan, we have switched to 800MHz dispatching and our paging goes live on Monday. Apparently when that happens we will no longer be getting emailed recordings of our dispatches. Occasionally there are recordings (certain calls, final tones, etc) that I like to keep. Is there a way to use the mini usb connection to download recordings from the G5 pager, and if so, what do I need to do that? I tried searching the forum, but came up empty - I don't know if that means I didn't put in the right parameters for the search or if it hasn't been addressed before :D Thanks for any help ..
sirmouse
Ada MI
It's been years since I've played with it but at one time the "Message Backup Software" exported the audio from the pager. Downloads- G2-G5 P25 Voice Pager | Unication USA I would bet it still works.
so I'm connected and the software sees the device, but when I click import it finishes immediately with zero messages downloaded ... it appears it does regular messaging (text or voice messages) ratgher than the pager recordings?
KB8KOJ
Centerville, Ohio
Very odd, I am seeing the same thing. However I fired up a virtual machine save of my old Win7 install that had the software installed and as you can see it worked at that time. Did a firmware update cause it not to work anymore? is there a setting we need to allow in the pager? Someone still has to be using this I would think.
