Downloading the Proper Drivers for Connecting my 396 via USB
Los Angeles, CA
#1
SO I want to be able to connect my 396 to my laptop, so i got the USB connector. Where do I find the drivers so that the ARC or UASD program on my laptop can connect to my 396?
Sam
#2
the drivers are for the connector not the software, what USB cable do you have? if it is the one from Uniden get the drivers for Prolific. If you do a search here you should find a link for the drivers. If the cable is made by someone else do a google search for the drivers.
