DP 1400 Programming
zs6jpl
Pretoria, South Africa
I just want to confirm something around programming the DP 1400 portable's with the experts since I have not programmed one of them yet. It appears that you use a standard Micro USB cable to program, is this correct. If so where on earth do you plug it into the radio? I have all the other DP xxxx Basic Service Manuals but not the DP 1400 one so I can not check this.
Johan
ZS6JPL
KG4INW
Midlothian, VA
That appears to be the EMEA version of the CP200d. Yes, a micro USB cable will work (but I seem to recall only if the plastic isn't too thick for the cable to seat properly) and it plugs into the port underneath a small plastic flap just below the side accessory connector.
