DP1400/CP200d - 32 channels
Marco192
I pretty new to Motorola CPS and firmware, so please help me with this one ...
I have successfully updated a DP1400 radio (CP200d in US) to firmware R01.30.30.
According to user manuals with that firmware radio should have 32 channels (16 ch in 2 zones) but I can not see it.
I can't get the second zone programmed ... what should I do to fix it?!
I have CPS 16.0 that works as should.
Thanks for the help!
Floridarailfanning
Tennessee
In CPS right-click Channels then click Add Zone. If that option is not listed when you right-click make sure you are using Expert view. If you still don't have the option to Add Zone, then the particular model of radio you have likely doesn't support multiple zones.
Marco192
I do have "add zone" option (and it is clickable) but when i click on a message pops-up telling me that the maximum number of zones is 2. but there is only one zone + the channel pool.
The other problem is that I don't have an option to assign "zone toggle" to a button on a radio.
I am not aware that this is a hardware related function. All the info that I have come across says that it's a function added by a later firmware version.
Floridarailfanning
Tennessee
I just opened up the sample codeplug and I see what you're saying about the popup about only having 2 zones, and not having the Zone Selection option for a button. Since you have CPS 16 I would try updating the radio to R02.XX and see if the issue is resolved.
I've always hated the way zones work on mototrbo portables because it's a pain to configure on the low-end non-display radios, and virtually pointless on the XPR7000/DP48 radios because the channel knob is continuous.
Marco192
I agree, the zone system has stayed the same for years with no improvements. one should really have a radio with a display for anything beyond basic, one-channel work.
I could try updating, but just for testing purposes that would be a large expense
N1GTL
CT
I think you're screwed on the second zone on this one. I just tested your issue. I have one zone and a channel pool. When I try to add a second zone, it tells me a maximum of 2 are allowed. The channel pool is being counted as a zone and it cannot be deleted. What is odd is that the channel pool is for IP Site connect on these radios and this radio is analog only so it is not even capable of IP site connect. Interestingly, I can also enter a RAS key which again is for digital channels but the radio does not have digital.
I have added two zones to CP200 radios (not sure if it was CP200d) using a button to toggle between 1-16 and 17-32. The radio beeps when it switches and the top light may flash if you're in the second zone (I don't recall). Don't go crazy, I don't think it will work.
Marco192
Thank you both for taking time and testing my issue!
@N1GTL
CP200 can be upgraded to a DMR radio via a software licence, so that's why it has all the digital features.
My situaution is exactly as described by you. It would seem that the channel pool is counted as a zone, but it is not.
I won't go crazy :) ... but I would like to find out what's the story. Why do some radio have 32 channels and others do not.
alcahuete
Southern California
I've never heard of this, TBH, but I looked it up, and there are indeed 32 channel CP200d radios for sale brand new. So there almost has to be some way to make it work via firmware, I would think, as I'm pretty sure the hardware hasn't changed.
