DP4600e Programming Error
zs6jpl
Pretoria, South Africa
I am stuck between between a rock and a hard place with my new DP4600e handheld. I attach the cable to the portable and the PC USB port. When I turn on the portable it gives me "IMPRESS Accessory" connected as it should. My PC asks for the network to be discoverable and puts MOTOTRBO Radio adapter in my network adapter list. Everything behaves and looks normal. When I run the CPS 2 to read the radio I get the following error:
#1001687 Unable to detect applicable device(s)
I tried different PC's and also tried with CPS 1. I keep on getting this error. Does anybody have a idea why this is going on?
Thanks so much
Johan
Tech21
try reading it in 16.0 and update the firmware if it that works.
Rahel
Try to use another code-plug for the same model... then try to clone the code-plug to the radio, after that you can easily read the radio
I believe this will work out.
