DPS Pierce on P-25
Wayne
Heard DPS Pierce (KUZ831) testing radios in digital mode today on 155.535 and 154.7025. I guess the rest of Region 2 (Houston) cannot be far behind.
Edit: As of this afternoon, they appear to have made the switch to digital on the Richmond repeater. All comms are routine traffic enforcement and are digital.
Wayne
hiegtx
Dallas, TX
executioner said:
So how do I set this up in the bcd396? I am still getting the Brazoria County Dispatch on analog.
For any conventional frequency that you know (or suspect) is using digital, do not set any PL/CTCSS tone of code. Also do not set it to ignore a tone, or to "Code Search". Leave that field set to "None". If you have a tone (or code) set, or search, whatever, you will not get any digital mode transmississions.
We're starting to see a few of the surrounding counties or cities in the North Texas change from analog to digital on their dispatch frequencies. Greenville, for a while, was mixed mode, some digital, some analog. If you entered the DPL code listed in the database, you'd never hear the digital communications.
That's one reason I went ahead and ordered a 996. You can specify a frequency as analog only, digital, or both. Wish that was an option on the 396 as well, but it may well be something hard coded in the processor firmware, not addable via a flash download. As a workaround, I've set aside a separate DPS group in my 396 without without tones or codes, & given the group a name reflecting that. The Dallas region is not digital yet, so I have that group locked out, unless I travel west or southwest, into areas where digital conversion for DPS is more advanced.
The other DPS groups have the mobile repeaters text-tagged, and the appropriate PL/CTCSS entered, so that I can identify the area. For your specific case, leave your Brazoria dispatch as is. Enter the digital use frequencies noted above without tones or DCS codes (leave selection to "none").
Wayne
DPS Pierce is now digital
DPS Pierce used to have atleast three analog dispatch frequencies; 155.535 (Northeast), 155.445 (Southwest) & 159.210 (Northwest). I heard some radio testing last Friday on 154.7025 which is usually the input to 155.4525. I have not heard any activity on 155.4525 so far but it is possible they are experimenting with the output power levels.
Has anyone verified Pierce DPS digital on any other frequencies other than 155.535 and 159.2175? From the Galleria area I used to be able to hear Pierce on 155.445 analog, but nothing in the last three days...
Wayne
