DPS re-districting info
Mesa, AZ
#1
Heard some interesting comms today from DPS.. Dispatcher calling Metro South Units. From what I can gather south is referencing south of the 60 and other areas. This was heard on Metro East Channel.
cellphone
Ahwatukee, AZ (Phoenix)
#3
Callsigns for South units seem to be 18xx. They are using Metro East freq.
On APBs, code 34s, and debris calls, dispatchers are calling "District 13 Units", "District 18 Units", or "All East Units".
radiochuck
Phoenix, AZ
#4
In this case, the dispatcher said "I need a Metro South unit for debris in the roadway, ...". But yes, I'm sure the preferred protocol is as you've stated.
By the way, cellphone, that's an cool callsign you've got there.
rpgaun
Sun City, Az
#5
Metro South Channel Change?
This morning I heard the Dispatcher on Metro East tell all the District 18 units to 10-52 (change channel) to South. I then thought (it was breaking up) I heard the 1800 units checking on with a Dispatcher on CID 1.
Anyone else with intel on this?
FLANO
AZ DB Administrator
SE of Tucson, AZ
#6
Richard,
Did you try the "YRCS" 800 mhz TRS ?
I have been hearing a lot of "south" activity on TG 1014, DPS CI South.
Yuma Regional Communications System, (YRCS) Trunking System, Yuma, Multi-State - Scanner Frequencies
cellphone
#7
I can also confirm that "Metro South" units are using CI1 for dispatch. On YRCS, there are no talkgroups active with patches, and no unusual talkgroups popping up.
JohnSpartan
#9
I talked to a trooper last night, and he says they will be moving to that channel on a regular basis, if not full time soon, he just wasn't sure when.
#10
Well, the northern Arizona rule of not traveling south of Camp Verde from April to October has passed so my wife and I may be headed that way soon. I want to understand this Metro Southern District thing and want to verify that the CI1 channel is the UHF frequency not the Yuma Regional system talkgroup. If so then 460.275 MHz. Anyone catch a PL? 100.0 or 151.4?
JohnSpartan
#11
UHF Analog CI 1 is currently being used as District 18 Metro South. Frequency is 460.275000 PL 100.0
So far, the YRCS patch is intermittent. I haven't been able to recognize a pattern of when they do it.
JohnSpartan
#12
DPS still hasn't added info about district 18 to their website, they did however add "Night Watch District 7" which is on District 5 (Metro Central) during the overnight hours. The callsigns change from 5xx to 7xx with the third shift. From what I can tell, this is only done in the Central district, West, East & South keep their respective unit numbers. Anyone else confirm that?
Phoenix, AZ
#13
West, East, South and Central are all 7xx for night watch. 710/720 central, 730/740 east and south, 750/760 west.
