Have been trying to get any performance at all out of a new Dressler ARA 100 HDX
active antenna for a few days now.
Advertised to cover 40 KHz to 100 MHz with the expensive HDX model specifically for
urban areas with high ambient RF or close tower proximity, nothing we can do
will coax anything out of it.
It is worthless on all of HF and can't even pick up the California Highway Patrol on 42.xx
that our Unidens easily pull in with the rubber ducks.
Tried roof mounting, ground, dozens of locations where even a simple wire on HF gets good results - the Dressler is equally lousy no matter where it is. Nothing makes any difference.
We checked the power outputs and cable obviously and tried with several receivers that
are working perfectly with all other antennas. Adjusted the gain on the Dressler to no end.
No wonder the only US distributor is on eBay. Interesting that the power supply has
a bad homemade typed label stuck sideways onto it and the Dressler antenna label
states "40 KHz to 60 MHz" while the xeroxed 'manual' claims 40 KHz to 100 MHz.
The preamp (RSM2000) shows "DC supply 250 mA max" but the AC adapter outputs
12 vdc 1000ma. And the suspicious looking "ARA 100 HDX" label stuck on completely
crooked and peeling off tops it off.
Unless it is completely defective in the antenna pre-amp it's easily the most useless piece of equipment I've seen yet - you can easily get better signal out of anything than this (and
for far less than $600)
any band or frequency.
