R8600 DRM using the 8600?
wb4sqi
Amelia, OH
Anyone here tried Dream software with the 8600? Even better, Dream on OSX and 8600?
Thanks in advance.
N1FKO
Your question made me curious, so I spent the day doing a little investigating. The immediate bad news is that the last distributed app that works on macOS is 2.1.1, a 32-bit binary from 2013. The 2.2 app from last April is 64-bit but blows up as soon as you run it. There's been no new ready-to-run binaries (for any platform) for almost a year; I'd say the project is still very much in development rather than a product.
That said, if you can run 32-bit software it's worth a try. If you've upgraded to Catalina you will have to build your own from source. If you already have Xcode/HomeBrew/MacPorts installed you can do as I did and muddle your way to a working app (I used the Yosemite build instructions as a guide). If you're not familiar with everything I just said you may want to stop now.
The IC-R8600 is plug and play on macOS. You set the USB port you want to use to IF out in settings and plug it in. On Catalina the app does not know how to ask for permission to use the USB audio interface, but if you run it from Terminal then Terminal will ask and it works. One caveat: by the time I figured all this out there were no DRM broadcasts to be found, but I was able to demodulate AM and FM signals without any problem.
I'd say that if you value your time you should just buy one of the many cheap DRM receivers available - if there were any!
wb4sqi
Amelia, OH
I had not made it to this point so that's why I asked here first, figured someone might know a bit more than me.
I am running Catalina. I recall seeing info about Xcode/Homebrew/MacPorts but did not pursue. While I enjoy using my MB Air I'm not well versed in "building" a working app. I have a couple of Win laptops that would make suitable DRM donors.
Nice to know about the 8600 and macOS.
The reason I asked, I belong to other SW forums and DRM came up as a subject in a post and received a lot of comments. Although the mode has not "taken off" as originally hoped for there are some SW broadcasters using it. Unfortunately the only way to listen is via computer app so the intended audience never developed.
I guess DRM was a grand idea but poorly implemented. Thanks for your reply.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Here in the US, the FCC listens to those that have the deepest pockets. The firm that runs HD Radio have very deep pockets and for all intents and purposes, pushed the DRM Consortium - which has very little if any stroke here - right out of the picture. Combine that with the lack of DRM capable radios (the few that show up at places like Universal tend to disappear very quickly) and you have a mode with no market and no push to make it happen...Mike
