dsd+ error
Arkoma,OK
#1
DMR CACH ERR slot 1 BS DATA ERR2 DCC=8 IDLE
slot 2 ERR2
ERR3
ERR1
Just got DSD+ 1.74 installed and I'm getting this error. It goes on forever and has some other errors listed, but
this is first issue. Any advise
kh6sz
Gulfport, Ms
#2
slot 2 ERR2
ERR3
ERR1
I get many errors like that when the signal is not strong enough. DMR needs a nice strong signal to decode properly.
natedawg1604
Denver-Metro
#3
FYI, you should also upgrade to 1.101 (the latest public release). And try moving your antenna around to get a better signal. In my experience, DMR systems will often decode somewhat okay even with some error messages.
Sometimes you can't make all the errors go away because you're too far away from the site to get a good signal. It seems like many DMR systems at fixed locations use low-power sites, which can make monitoring difficult if you don't live close by. Antenna placement is crucial in any event.
