DSD fast lane encryption key
lkas
Cheektowaga NY
I installed DSD fast lane paid version. I am still learning to use this but am able to pickup analog and P25 channels so far. It claims to display the encryption key on a encrypted freq. I have tried this on 2 DMR encrypted freq but i am not seeing the key. I have the even log menu set for "encrypted voice call following - full following". I attached a screen shot of what i am receiveing. Any suggestion to get the key to display?
I don't believe DMR broadcasts the key (which is NOT the actual encryption key, just the key ID number), I've only seen it on P25 myself.
CanesFan95
Was Homeboys-Scanna
Banned
FL
That's not the actual encryption key. No system is going to just divulge that for the world to see. What it's showing is the Key ID which just the numbering used to program keys into a radio (a radio can have more than 1 encryption key loaded into it). For example, encryption key #1, encryption key #2, etc., but not the actual key itself.
The encrypted voice call following is only telling DSD+ if you want to stop on encrypted TGs but does not actually decode 'em cause you don't have/know the key. If you opt to tell DSD+ to stop on encrypted TGs, you will not actually hear anything, or maybe an initial blip of encrypted noise until DSD+ mutes the audio altogether.
lkas
Cheektowaga NY
maybe i am mistaken. I assumed that the "key" i have been seeing everywhere online in refernece to DSD fastlane was the encryption key.
cg
Connecticut
It doesn't display the key, it displays the key number. So if I have a multikey radio, I may have 5 keys for 5 channels or systems.
The program shows the "alias" of the key for lack of a better term. Nothing to do with monitoring the encrypted conversation.
lkas
Cheektowaga NY
I knew it would not monitor it because it was encrypted. I guess i was just confused and thought it would display the encryption key.
Wouldn't be any reason to encrypt if the key was easily available. You just missed the word ID after key, it is the encryption Key ID only.
GTR8000
NY/NJ Database Guy
BEE00
As has been stated already, it displays the KeyID, not the actual key data. Key data is never broadcast over the air, as that would defeat the entire purpose of encryption if it were that easy to capture the actual key data.
As for DSD+ showing the KeyID, you're only going to see that broadcast over the traffic channels, not over the control channel. You need to allow DSD+ to tune to encrypted transmissions in order to see the KeyID.
ki4hyf
Ridin' Dirty
Jackson, TN
Lastly, there are no key IDs for DMR Basic Privacy.
Out of all of those replies, you are the only one who answered correctly. Everyone else was talking about RC4 or higher encryption, and they (for the most part) were correct about KeyIDs.
