DSD+ Fast Lane
sameehosen
HAMPORG
Not the most successful, despite using the program to read the instructions
The previous version DSDPlus1p074
I could hear sounds well and was able to decode clearly DMR
- I try to run the program by taking advantage of the discriminator and what I care about is the voice signal decoding DMR
Any tips or settings before you will be appreciated
Thank you and respect
Forts
Mentor
Ontario, Canada
Really not sure what you are asking.... doesn't work with discriminator audio? Or 1.080 isn't working for you? Or both?
sameehosen
HAMPORG
Thank you respond and attention
The new version works DSDPlus1p080 Fast but not efficiently release DSDPlus1p074
I no longer hear the voices are clear on the same previous channels that you listen to it on the issue DSDPlus1p074
- I wonder if the new release Fast Line had improved signal decoding DMR?
- Or I'm not the best use of the new program to make it work well
Any advice would be appreciated and thank you
Ghstwolf62
Clifton Forge Virginia
I think he's saying decode seems to be degraded in newer versions.
I noticed this as well with 1.74 vs earlier versions. (P25)
Had to really play around a bit to get it back to nearly as good as before.
Boatanchor
Is there any progress on reducing the 'compressed' nature of the recovered audio in DSDplus?
I note that the P25 audio (can't comment on other digital modes, since I don't have any other local systems to monitor) sounds highly compressed compared to audio from a Uniden or GRE scanner.
For example, background/ambient noise that is barely audible on the hardware radios, is virtually the same level as the voice in DSDplus. It does make long term monitoring a bit arduous.
Anyway, I do appreciate the work you guys are putting into this project.
I'm loving the logging capabilities of v1.074 :)
kf4bzt
San Antonio, Texas
Payment Sent
Hi Guys,
Just to let you know that I submitted the payment and I am using a gmail account as mentioned from PayPal. I hope GMail does not cause issues.
Tim
KF4BZT
slicerwizard
Toronto, Ontario
From the 1.090 Notes.txt:
Control of AMBE and IMBE unvoiced audio levels has been added
-UA<num> AMBE unvoiced speech level (0-100) [-UA50]
-UI<num> IMBE unvoiced speech level (0-100) [-UI50]
pressing 'A'/'a'/'I'/'i' will also adjust the levels;
lower levels may reduce the "underwater" sound of some comms
Did some A/B testing and lower values definitely reduce the level of background sounds.
Boatanchor
Thanks slicerwizard, great to know. :)
Sponge9
Hobart Tas
I know its an old thread but could not find anywhere else to post just sent $25 for fastlane access to the paypal account so hope this is how it still works.
W5RGP
Charlotte Tn
yep i just signed up a couple weeks ago had mine emailed to me the next day.
