DSD help
#1
I am trying to monitor this but get errors. A screen shot is attached of the errors. Do I have a setting wrong? Thanks.
SpugEddy
Camden County South Jersey
#2
What are you using to send the data to DSD?
That is to say, what software are you using to
tune in the frequency? SDR#, HDSDR, etc?
When I used SDRsharp, I had a helluva time tuning
in for DSD. It was tedious but you need to fool with the
gain, turn off all filtering, play with volume, until you get
it right
#9
Do you need the discriminator audio or from the earphone jack? This unknown department is not on alot and the CW ID is to fast for me.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
#10
Discriminator audio is a must - nothing less for digital signals. Just record a raw audio file in DSDPlus by starting up DSDPLus and pressing 'R' to record raw audio. Record it for a minute or two. Then press "R" again to stop the recording of raw audio.
Find that raw audio file in your DSDPlus folder -- In case you have more than one raw audio file already, it will be the the latest timestamp. It'll look something like this:
DSDPlus-Raw-Input_2018-10-05@000444.wav
Make it available somewhere that you can provide a link to so that it can be downloaded by others.
Mike
#12
Thanks for the help. The signal is weak today. The frequency is 151.67. I have not found anything in the FCC database. I'm in Trumbull County Ohio. Have checked in PA also since I'm not far from the boarder.
