DSD-Linux?
Nevils, GA
#1
What, please, is the latest news re. DSD for Linux?
I read the Ubuntu post but am interested in running it under Puppy Linux on a laptop/netbook or (if possible) under Linux on a BeagleBone-Black or a RaspberryPi
Thanks!
David
#2
Thanks!
David
It won't run on a raspberry pi, I have it running on a MK808 android TV stick running picuntu and custom compiled kernel with oss audio enabled. I've stopped playing with that at the moment as I am working on the NXDN trunked voice decoding.
Nevils, GA
#3
Are dsd-1.4.1-src.tar & mbelib-1.2.3-src.tar (Digital Speech Decoder 1.4 Copyright (C) 2010 DSD Author) the latest & greatest for Linux?
Why not the RaspberryPi, please?
What about the BeagleBone-Black?
Did you post details as to your MK808 success?
#4
I have my own versions of DSD.
Raspberry pi is too slow.
BeagleBone-Black will also be too slow.
Cortex-A9 dual core (RK3066) @ 1.6Ghz is about the minimum CPU you need.
Whatever you use I found it easiest to compile a custom kernel with oss enabled rather than using pulse audio.
I have it running ok on the MK808, it does have an occasional crash but is pretty good.
I also tried to get it running on a Nexus 7 with ubuntu installed but pulse audio wouldn't play ball and I never got round to trying to compile a custom kernel for it.
I picked up a cheap tablet last week with an RK3066 CPU in it, not had time to try that yet though.
