Dsd plus (beating a dead horse)
k4ktr
Elizbethtown,kentucky
Hello I have dsd Plus installed i use a gre psr-500 with a tap on tp-4 when i start up dsd it decodes nxdn for 30 seconds then quits it will never decode dmr or p25 i have tride it on an xp laptop and on a dell laptop one with a sigmatel audio cand and the other with an hd audio card what could the issue be when it decodes non encrypted p25 it says that it is muting the encrypted ch
slicerwizard
Toronto, Ontario
How old are these laptops? What processors do they use and what are their clock speeds?
To resolve audio problems, check for advanced audio options like noise filtering and disable them. Upload raw audio samples so others can inspect them.
M105
Check your microphone input levels. On some old laptops microphone boost might be needed. Also check that any built-in microphones are disabled. I have seen cases where plugging in the mic cable does not mute the internal microphone.
