DSDPlus DSD+ Question
GrumpyGuard
NEWBERG
I am new to DSD+ and have a question. Using Radio Reference I found the control channel for the NXDN NEXEDGE 4800 system I want to listen to. I put that into FMP24-CC.bat as I am using a generic DVB-T +DVB FM USB. When I start FMP24-cc.bat and 1R.Bat I don't see the system. What value should I put in -P0.0?
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
I'm guessing you are monitoring this one?
Keep in mind that if there is just one freq on an NXDN site marked as a CC, that doesn't mean that some of the other freqs on that site couldn't be CCs. It just means that when somebody discovered that site, the CC at that time was the one you are using. Check all the frequencies on that site for an active control channel. When you tune to the freq, you would see the signal in FMP and you would start seeing information at the bottom of the DSDPlus Event Window
Here is the license for the Newberg area site - FCC Callsign WQTD608 (COMMUNICATIONS NORTHWEST) with the following frequencies:
451.06875
451.15625
461.44375
461.54375
461.73125
462.15625
There very easily could be more freqs active on that site since the last time somebody monitored it and submitted data to the DB. And on many systems, any freq could be a potential CC or they often have at least two CCs and may or may not rotate them periodically.
