No connectivity between FMP and DSD+
I haven't used DSD in quite a long time, but the e-mail announcing the recent fast ring release prompted me to get back to it.
I'm sure I'm doing something wrong so I figured I'd ask if anyone here can point out the obvious part I'm missing.
I'm using RTL-SDRs, and I have the proper driver installed. FMP sees and tunes my RTL-SDR properly. I see signals on it's spectrum analyzer and I see channel activity on the audio analyzer portion.
When I start DSDPlus, it doesn't seem to get any audio from FMP. The VC Source Audio window remains blank, with a slightly darker blue line in the middle.
I'm going to paste the outputs of the commands below in case there is anything useful. I'm running Win10 Pro, Anniversary Update.
Thanks in advance!
-Mike
Here are the command line parameters I'm passing to FMP and DSDPlus:
Commands said:
FMP.EXE -i1 -o20001 -f147.105
DSDPlus.EXE -i127.0.0.1:20001 -g250 -o1 -rv -fa
I thought it might be a firewall issue, so I added exceptions for both binaries. When that didn't work I disabled the firewall entirely and still had no success.
FMP said:
FMP rev 1.4t
SDR sampling rate = 1.008 MHz
Spectrum window width: 512
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000
DSD+ path: '.'
Primary frequency list: '.\FMP-FreqList.csv'
Secondary frequency list: '.\FMP-FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Using RTL SDR device #1
Using TCP port #20001
Initial frequency set to 147.105000 MHz
SDR device count=1
Found Rafael Micro R820T tuner
Tuner type=5 (R820T)
Sampling rate set to 1.008000 MHz
Exact sample rate is: 1008000.009613 Hz
RF gain set to 49.6 dB
frequency correction factor = 0.0 PPM
No frequency data files found
Listening on TCP port 20001
Accepted connection from localhost on port 50383
TCP error = 10035
[A non-blocking socket operation could not be completed immediately]
DSDPlus said:
DSD+ 2.29
Setting output audio gain to 250.000
Program role is voice channel decoder; audio modes set to mono
Appending synthesized audio to file 'VC-DSDPlus.wav'
Current working directory is "D:\DSDPlus2p29"
0 frequency records loaded
0 radio records loaded
0 group records loaded
0 site records loaded
0 network records loaded
Assuming FMPA/FMP24 is signal source; auto polarity detect is disabled
Initiating TCP connection to 127.0.0.1:20001...
Connected to 127.0.0.1:20001
audio output device #1 = 'Speakers (High Definition Audio'
audio output device #2 = 'Digital Audio (S/PDIF) (High De'
audio output device #3 = 'Headphones (High Definition Aud'
audio output device #1 (Speakers (High Definition Audio) initialized
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated; press Esc to exit...
