dsdplus does not decode this signal
rspc
Hello!
I've been trying to decode this signal for some time, which I think is dpmr gone but the dsdplus does not decode it.
Have if among all we can and so add more systems to the decoding.
Attachment web link download copy and paste in the browser.
Thanks greetings!
https://www.dropbox.com/s/mgs5vpgj2ag4v0w/no decoding.zip?dl=0
Hola buenas!
Llevo tiempo intentando decodificar esta señal que creo que es dpmr idas pero el dsdplus no lo decodifica.
Haber si entre todos podemos y asi añadir mas sistemas a la decodificacion.
adjunto enlace web descarga copiar y pegar en el navegador.
Gracias, un saludo!
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Hello!
Thanks greetings!
Hola buenas!
Gracias, un saludo!
1. add the "-fm" switch
2. there currently is NO voice decoding support for dPMR
3. If I were you, I'd send that raw audio to dsdplusfastlane@gmail.com
Perhaps the reason why there currently is no dPMR voice support is because the author doesn't have any/enough raw audio of voice frames in order to create the decoding algorithms.
4. I'd recommend a bigger voice sample if possible -- 10-20 MB of raw audio containing voice traffic -- send to dsdplusfastlane@gmail.com -- or upload it to dropbox and send dsdplusfastlane@gmail.com a link to it.
Code:
Decoder options:
  -rc         role is control/rest channel decoder
  -rv         role is voice channel decoder
  -p          Invert signal polarity (may be required for X2-TDMA and dPMR)
  -p-         Disable auto polarity detection
  -mp         optimize for PSK modulation (will not decode non-PSK)
  -fa         Auto-detect all protocols / frame types except dPMR [-fa]
  -fd         Decode D-STAR
  -ff         Decode Fusion
  -fn         Decode NXDN4800 (Kenwood NEXEDGE and Icom IDAS)
  -fN         Decode NXDN9600 (Kenwood NEXEDGE)
  -fr         Decode DMR/MotoTRBO (TDMA inputs + both output slots)
  -f1         Decode P25 Phase 1
  -fx         Decode X2-TDMA
  -fp         Decode ProVoice
  -fm         Enable dPMR decoding (no audio)
Mike
rspc
Thank you very much!!
Try the functions -fa -fm -fn but no luck.
I'm going to make 10-20 MB of raw audio that contains voice traffic as you tell me and send it to dsdplusfastlane@gmail.com and try to help the whole community.
Thank you very much, greetings!
Muchas gracias!!
Probe con las funciones -fa -fm -fn pero sin suerte.
Voy a realizar 10-20 MB de audio en bruto que contiene tráfico de voz como me comenta y se lo envio al correo dsdplusfastlane@gmail.com y intentar ayudar a toda la comunidad.
Muchas gracias, un saludo!
mtindor
OH/WV DB Admin
I used just -fm . And with that option, DSDPLus DOS window did indeed show that it was seeing the dPMR packets and indicated that they were voice packets. DSDPlus simply doesn't support dPMR voice yet.
That'd be great. Yes, it would benefit us all if there were support. I appreciate your willingness to package up some raw audio and send it to the dsdplusfastlane@gmail.com address. NOTE: you may have a problem sending a WAV file over 25 mb, and you may have an issue sending a .zip through Gmail. If you run into problems, simply upload the file to Dropbox or somewhere and then send the link to the dsdplusfastlane@gmail.com email.
You're welcome, and thank you for making the effort to provide audio so that maybe dPMR could be supported in the future.
Mike
rspc
We have already sent a zip with material,
if you can in the future available icom idas dpmr in dsdplus fastline, anything to help.
Ya hemos enviado un zip con material,
haber si se puede en un futuro disponible icom idas dpmr en dsdplus fastline, cualquier cosa por ayudar.
*Muchas gracias, un saludo!
