dsdplus p25 trunk tracking
natedawg1604
Denver-Metro
#2
Yeah, if you use Unitrunker you can build multiple voice receivers, with each receiver attached to a separate dongle and piped to a separate instance of DSD+. You will also need Virtual Audio Cable to pipe the various audio streams from Unitrunker to DSD+, I think it costs $20 or $30. But with multiple Unitrunker receivers you can monitor multiple talkgroups at the same time, and DSD+ allows you to pipe audio to discrete speaker channels. So if you had a 6-channel sound card and 3 sets of speakers, you could presumably monitor 6 talkgroups simultaneously, with one talkgroup routed to each of the six speaker channels. (You would need 7 dongles total and a pretty healthy CPU to run 6 Unitrunker voice receivers at once, but it's certainly quite doable).
mattnelson26
Hopkins, Minnesota
#3
I'm really looking to run this through the FMP function so I can run trunk track and hold different channels if they're active or something major is going on.
Matt
natedawg1604
Denver-Metro
#4
Matt
Well, if you used FMP/FMP24 and you have 4 dongles, you could monitor 2 talkgroups at once. You need 2 instances of FMP/FMP24 and 2 instances of DSD+ to monitor a single P-25 talkgroup. So double that for every talkgroup you wish to discreetly monitor with FMP/FMP24.
adcockfred
Aldine, tx.
#5
Is there a voice recognition software that can recognize ernest in a voice? I want to do the same thing matt does, but I am not worried about in put.
