DSDPlus DSDPlus.radios
Mr_Sample
Are any made bat script for reset hits in DSDPlus.radios files ??
i am thinking how to do it but don't have any ideas, because i have more then 1600 radios in list and its not easy to do that by hand.
any ideas ?
a417
You will either have to 'SHIFT + right click' the file and use "Open With..." and the find excel, or open in from excel using the File ---> Open button. The file extension '.radios' is not registered to excel in your registry, so excel will not default to open it.
as @slicerwizard stated, it is a comma separated values file (CSV) but it is not registered with the OS as a file with a .CSV extension.
a417
I will also strongly advise you to go to your file explorer 'View' settings and make sure 'file name extensions' is checked. This will force Vinders to show you the file extension, and you can hopefully prevent yourself from having 'DSDPlus.radios.csv' issues. Especially helpful since DSDPlus places great weight on the extension as a method of configuration file management.
